Stock spoiler help!!
Old Jun 9, 2005 | 03:41 PM
jaehyun127's Avatar
Hey guys, i just got the INGS+1 rear spoiler and it seems that this spoiler uses the EXACT same 4 bolts that the stock spoiler uses.
Apparently, the JDM rx-8 comes w/ the stock spoiler??
Regardless, Does anyone have a template or installation instructions for the STOCK OEM SPOILER for the rx-8? And any pictures of the bolts/sizes, and anything that comes w/ the stock spoiler??
HELP!!! :o
Old Jun 9, 2005 | 03:42 PM
outla has the wing...ask him
Old Jun 9, 2005 | 03:52 PM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
I didn't have a stock spoiler when I had the Ings installed. What I did was just some charcoal markings where the wing is suppose to be drilled.. use a paper on the trunk, and gently lowered it to mark the spots that will need to be drilled. Then slowly take off a side of the 3M tape... but not all of it, and apply the wing to the trunk. When you are sure it's lined up correctly, tighten the screws, then grab the side of the 3M tape part and pull it out, apply pressure on top of the hood for a few minutes and you are ready.
Or you can go to the dealership and ask for a copy..
Old Jun 9, 2005 | 06:50 PM
Mikelikes2drive's Avatar
^ you must've been freaking nerve recking to drill into your trunk! i know i would be
Old Jun 9, 2005 | 06:56 PM
I didn't do it alone... Bodyshop helped me out, but I suggested lining it up with charcoal since I did it previously on a friend's car. Then he drilled it... etc etc.
Old Jun 11, 2005 | 01:05 AM
jaehyun127's Avatar
do you know the size or part number of the bolts that teh stock spoiler uses??
Old Jun 14, 2005 | 10:58 AM
cosmicenergy's Avatar
Whats that beeping noise?
I would like to know the size of the bolts to install the stock spoiler also. If anyone has a template that would be great also.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Digitz0070
Oct 7, 2015 12:43 PM
duworm
Oct 1, 2015 04:57 PM
