ok, has anyone done an msd or other aftermarket ignition yet
Old May 12, 2005 | 06:26 PM
lurch519's Avatar
www.evoperform.com
hey all, i have been doing some research, and i think i want to install an msd dis-4 and aftermarket coils to help get a little more spark energy and hopefully improve the fuel economy.
my question is has anyone installed any aftermarket ignition system and if so , did you encounter any problems.....................
thanks for any info
Old May 12, 2005 | 07:33 PM
expo1's Avatar
He's as bad as Can
There are no after market ignitions & coils for the RX-8. If there were more spark will not do anything for fuel economy. Nothing helps fuel economy it's a rotary. The closest thing out there would be to get a Canzoomer piggy back unit and tune it yourself. Very little piston engine tuning knowledge applies to the RX-8.
Old May 12, 2005 | 11:11 PM
MadDog's Avatar
Consiglieri
MSD won't work. The AEM C2DI will work, though. The 8's coils fire on the leading edge of the pulse. The MSD will only fire on the falling edge. THe AEM can be set to fire on the leading edge. The MSD will end-up missing at high RPMs since it is not synched correctly.
The bottom line is that a CDI ignition won't help you much. They really help where you have the coils firing in wasted spark at high RPM. Since the 8 doesn't use wasted spark, and there is one coil per plug, the CDI is a waste of $$.
Old May 13, 2005 | 11:54 AM
lurch519's Avatar
www.evoperform.com
any idea where i can find a copy of the aem c2di instructions online so i can take a look at the wiring and installion
Old May 13, 2005 | 12:10 PM
expo1's Avatar
He's as bad as Can
Your charting new ground here best of luck. Two years worth of posts on this board and only four other threads mention aem c2di
https://www.rx8club.com/search.php?searchid=606661
The link below is for the RX-7 (FD) $1,600 It does show it "might" work with a ton of custom tuning.
http://www.coximport.com/store/30-1800
Old May 13, 2005 | 01:09 PM
MazdaManiac's Avatar
I had a write-up here about installing the MSD DIS ignition a while back. I don't know where it went.
Since I was using the E-Manage, I was able to resolve the trigger issue using a simple circuit with NPN transistors to invert the pulses.
There was, however, no real noticible advantage.
The MSD only has one cap, so it can only fire the leading coils.
The AEM is better because it has two caps and can fire the trailing as well.
It would be fairly easy to install the AEM and a set of DIS coils. Total cost would be around $600. I'm not sure if there would be any actual benefit.
I may do it in the near future just for ***** and giggles.
Old May 13, 2005 | 01:18 PM
lurch519's Avatar
www.evoperform.com
Thanks guys, i just need to find the instructions for the aem now.........
Old May 13, 2005 | 01:29 PM
Here:
http://www.mazdamaniac.com/pdf/AEM%20C2DI%20manual.pdf
Old May 13, 2005 | 01:38 PM
PUR NRG's Avatar
Originally Posted by MazdaManiac
I had a write-up here about installing the MSD DIS ignition a while back. There was, however, no real noticible advantage.
What, your butt-dyno didn't notice a dramatic increase in pull and acceleration from the mod? Inconcievable.
________
Smoking Vaporizers
Old May 13, 2005 | 01:43 PM
lurch519's Avatar
www.evoperform.com
awesome thanks maniac
Old May 13, 2005 | 01:44 PM
Heh. G-Tech didn't see it either.
The main advantages of a CDI are longer spark duration at low RPM (for economy and idle quality) and higher spark current at high RPM.
The factory coils supply enough current to always fire the plugs under normal conditions. My idle was always good. So, there wasn't much to improve other than eliminating the inherent problems with the stock coils which are temperature and dwell related.
Old May 13, 2005 | 02:00 PM
neit_jnf's Avatar
what about hks twin-power ignition? it works wonders on modded FD's fixing high rpm breakup.
Old May 13, 2005 | 02:19 PM
Perhaps.
However, the Renesis doesn't have high RPM breakup. Not in stock or lightly modded trim, anyway.
Old May 13, 2005 | 04:17 PM
lurch519's Avatar
www.evoperform.com
i think i am going to be doing the aem c2di and msd coils. once i start my new jobby job, ill be able to get it at a pretty good price. whooo hoooo, gotta love discounts
Old May 14, 2005 | 07:06 AM
neit_jnf's Avatar
Perhaps.
same can be said for the FD, breakup starts at higher boost levels (>15) or over 350ish whp. Depending on tuning of course, for example my chpped ecu dumps so much fuel up top (9.5~10:1 afr at 12psi) that power goes down and some people report improvements with amplified ignition to burn the excessively rich mixtures.
I'm thinking about getting the hks once I have the $$$
cliffkemp
Dec 24, 2024 10:48 AM
tjohnmeyer
Sep 28, 2017 05:03 PM
fc2se
NE For Sale/Wanted
Jun 1, 2016 08:55 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
drlubell
Sep 26, 2015 11:58 PM
