Reverse Camera
Old May 3, 2005 | 12:21 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Reverse Camera
Does anyone know of a good reverse camera that will fit in our key hole?
Old May 3, 2005 | 12:41 AM
TheDosDog's Avatar
Recovered Modaholic
I looked into one but finally went with the camera from Matt. I mounted it above the plate. It has a wide view angle and unless you are looking for it you won't notice it's there. The problem I saw with the keyhole was that there would have to be some serious modification to the tail light to get the camera flush with the surface. Otherwise it would be like viewing down a long tunnel.
Old May 3, 2005 | 01:02 AM
His is too expensive for me. How are you viewing the image?
Old May 3, 2005 | 01:13 AM
TheDosDog's Avatar
Recovered Modaholic
It displays on the Nav screen. The video switch autodisplays the camera picture when in reverse or you can select it and view it on the camera's channel.
Old May 3, 2005 | 01:24 AM
Do you have the AV box?
Old May 3, 2005 | 03:48 AM
hotpot's Avatar
From the picture, it looks like someone could easily unscrew the camera off. Or is it bolted from inside?
Old May 3, 2005 | 06:53 AM
TheDosDog's Avatar
Recovered Modaholic
Yes, I've got the setup from Mazdapartscom.
It is attached the bumper cover. You would need tools to remove it without destroying it. Where I am there is little problem with theft though and as I said, unless you are looking for it you don't even notice it is there.
Old May 3, 2005 | 07:30 AM
moRotorMotor's Avatar
Rotary eXperimental-8
The new Honda Odyssey has a back up camera that is neatly tucked under the square hole where the lisense plate light normally aims down. It is compact and like you guys have said, unless you are looking for it, you won't notice it.
Old May 3, 2005 | 01:12 PM
Nemesis8's Avatar
Bigus Rotus
Does the camera come with the AV Switcher box? Or did you have to buy it separate?
Old May 3, 2005 | 01:37 PM
TheDosDog's Avatar
Recovered Modaholic
It's separate.
Old May 3, 2005 | 09:16 PM
So, is there one that will work?
Old May 5, 2005 | 12:04 PM
How about this one?
http://cgi.ebay.com/ws/eBayISAPI.dll...771206659&rd=1
Old May 5, 2005 | 12:21 PM
Nemesis8's Avatar
Bigus Rotus
Did it say "Inside Mounted" ??
Old May 5, 2005 | 12:31 PM
"Mounted Inside will fit into most vehicle key holes - no other installation needed"
Old May 5, 2005 | 09:05 PM
truemagellen's Avatar
Attracts tree branches
I've seen that one in person...it is huge...meant for the key holes with the large ring around it...our key hole is small plus the metal for it in the trunk sticks out and prevents a clean install.
I'm working on a DIY right now for the backup cam I installed...I did it without cutting. drilling, or damaging a single piece of the car :D...I'm also adding in pictures and instructions for mounting it in two locations...with ease (the second location may require a little bit of drilling but is much harder to see)
I'll try to get the DIY finished sat or sunday...things are CRAZY around here
Old May 26, 2005 | 05:19 PM
I know you guys didn't think it could be done.
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-trunk-keyhole-camera-installed-62547/
Old Mar 11, 2015 | 08:12 AM
shohidul's Avatar
sorry i no i am late to this post but i just bought my rx8. im trying to install a wireless reversing camera but am having trouble locating the positive 12v wire on the reverse light. On my car i got two wires on a clip coming out the reverse light and they are both purple which is why i do not know wich is the positive. Could some1 help please.
Old Mar 11, 2015 | 08:40 AM
RX8cite's Avatar
a front camera would come in handy for lowered cars
Old Mar 14, 2015 | 05:50 AM
shohidul's Avatar
I'm not in need for a front camera, just the reverse one
theblinkof
Oct 4, 2023 05:24 PM
superROB23
Sep 4, 2015 01:22 AM
Banshee8
Sep 2, 2015 03:03 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
MolecularConcept
Aug 1, 2015 03:15 PM
