CanScan not Working...
Old Apr 17, 2005 | 06:10 AM
Jabberwock's Avatar
I have been trying to use the canscan for a few weeks now and tried so many things to try to get it to work.
I really don't know whats wrong with the CanScan. I hook everything up but the ECU Status stays yellow...
Does anyone have any idea whats wrong with it, how to fix it, or if there is something wrong I might be doing.
Old Apr 17, 2005 | 11:12 AM
Usually it is the COM port configuration on your computer. Go into the system properties and see which COM port the serial to USB adapter is using...change your CanScan to reflect that...should be good to go.
Old Apr 17, 2005 | 11:42 AM
Nemesis8's Avatar
Bigus Rotus
Yep, that fixed mine as well. I also noticed that I have to use the same USB port on my laptop for some reason. If I use a different one, it does not work.
Do you have the CZ CANScan or the Harrison CANScan? There is a different chip on the CZ unit to correct for proper O2 readings.
Old Apr 18, 2005 | 04:24 AM
Jabberwock's Avatar
I think its the harrison unit, unless the CZ one looks similar.
I already checked the COM port settings... That didn't do anything
Any other ideas?
Old Apr 18, 2005 | 09:30 AM
does the USB to serial adaptor work? If you have a PDA ...check and see if it syncs.
The adapters driver may need to be removed and re-installed?
CanScan may be broken?.....e-mail Dan Harrison and ask him how to test it with the hyperterminal software on the disc
Old Apr 18, 2005 | 10:45 AM
smrx8's Avatar
Any other ideas?
It the harrison one
Old Apr 20, 2005 | 01:27 AM
Jabberwock's Avatar
I was using a serial port.
I'll check with d harrison.
Old Apr 26, 2005 | 01:43 PM
slavearm's Avatar
Boost Junkie
I many times have to unplug and replug in the port on the car. Seems to fix it most of the time.
Old May 3, 2005 | 08:12 PM
musclecarconvrt's Avatar
I can't even get the proper driver loaded. My computer doesn't seem to even see the drivers on the disc.
stickmantijuana
Sep 4, 2015 10:31 PM
Riles
Nov 7, 2007 09:52 AM
MadDog
26
May 27, 2005 12:24 PM
jaehyun127
May 7, 2005 08:31 PM
therm8
22
Jan 25, 2005 06:05 PM
