A couple instruction requests
Old Oct 4, 2004 | 03:35 PM
devoid's Avatar
My doctor prescribed RX-8
Ok, so I've been searching the CanZoomer thread with no luck (maybe I should have been searching the entire forum?)
I just had a couple of questions, as well as requests for instructions.
1. Can/does the CanScan tool record full RPM or half?
a. If half RPM, is there a way to convert to full RPM? (If so, please provide instruction)
2. I've read the CZ unit can be programmed using full RPM. Is this now a stock setting?
a. If stock is half RPM, can someone provide instructions on how to convert to full RPM. (I know there is some sort of wiring, switch, etc, as well as converting the maps to full RPM involved, but could find no specific instructions.)
b. Is there a way to easily tell if you running half RPM or full by looking at the hardware? (I ask this b/c I don't have mine hooked up to a computer yet, and I'd like to make the change if necessary before I put it in the car, and then have to take it out again.)
Old Oct 4, 2004 | 09:55 PM
CanScan is full RPM...reads the ECU Can output
CZ unmodified is half RPM....can be modified by changing the wiring on the daughter board
I think stock they are still half RPM...except the ones setup for the E01 unit ( ST 3) which are full RPM
No real advantage to a full RPM map except not having to think about doubling the RPM values........
Ask Maurice how to do it.......
Old Oct 4, 2004 | 10:35 PM
epitrochoid's Avatar
Riot Controller
its real easy to do if you have the newer board. PM me your email, ill fwd the instructions
Old Oct 5, 2004 | 06:03 PM
r0tor's Avatar
well, if you log things in the Canscan and dump them to excel (which you pretty much have to to understand what your looking at) its pretty easy to just devide the rpm in half
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Hunterkelley24
Oct 1, 2015 09:11 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
