Trouble with Amp Power
Old Sep 19, 2004 | 08:40 PM
Tigerfootball's Avatar
Clemson, NOT Auburn
Exclamation Trouble with Amp Power
I have had my sub and amp installed for a little while now and recently i have been suddenly losing power to my amp. I will just be riding down the road and the sub cuts out. When i check it out, the power lamp isn't even on. So i decided to test the power connections by touching the positive wire with the negative wire, and no sparks or anything. So i know it is either the 12V source or the Ground. Well, i have tinkered around a bit and when i moved the 12v wire around a bit (where it is connected to the battery) the sub came back on. So i think it may be that wire. possibly a connection with the terminal ring or in-line fuse. Has anyone else had this problem? and can anyone help me to resolve this issue? Thanks a lot.
Old Sep 20, 2004 | 03:45 PM
s2l's Avatar
s2l
looks like you found your problem. But word of advice, dont test your wires like that. You're going to fry something crucial one of these days. Just get a cheap 1.99 test light from Kragens or something for that purpose. Id check all connections: at the battery terminal, both sides of the inline fuse holder/breaker, distribution block ( if you have it) and at the actual amp itself. Good luck!
Old Sep 20, 2004 | 03:49 PM
Clemson, NOT Auburn
Yeah i know, i just wasn't quite thinking clearly. I did find the source though, the connection to the in-line fuse was loose and i checked it today and it completely came undone. I will definately go the $1.99 test light route next time. i probably never would have thought about doing that. thanks.
Old Sep 20, 2004 | 04:10 PM
s2l's Avatar
s2l
Thumbs up
no problem. Glad i could be of service
yurcivicsux
192
Sep 12, 2017 10:54 PM
juicemantwon
Sep 26, 2015 12:30 PM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
just1jack
Sep 9, 2015 04:45 PM
