leading and trailing ignition split
Old Sep 14, 2004 | 02:34 PM
zoom44's Avatar
When talking with jim mederer at racing beat sunday i learned that the leading and trailing plugs are on 2 COMPLETELY different maps in the stock pcm. the trailings dont fire x amount later than the leading, they just fire whenever their map tells them to do so. the dont fire at all based on when the leads do and vice-versa. there is no consistent split as jim mederer put it "they are up and down and all over".
does the cz advance/retard leading AND trailing igniton? i just read a post by mazda maniac saying he does not. after the talk with jim mederer sunday im not sure its a good thing to do. but without getting at both you arent going to get a consistent split.
Old Sep 14, 2004 | 02:46 PM
brillo's Avatar
Go Texas Longhorns!
Now thats interesting, that opens up a whole can of worms when it comes to ECU tuning. Does the emanage/CZ box hanve the ability to handle this?
Old Sep 14, 2004 | 03:23 PM
rotarygod's Avatar
Yeah that was really weird. I like to run a fixed split regardless of load. At least I do as a base map. There usually isn't much change that needs to take place. If you are using an ecu that does not adjust leading and trailing independently, you are not getting the performance that you could be getting.
Old Sep 14, 2004 | 06:21 PM
Magic8's Avatar
Mazda Mole
Would supplementing an AEM ignition unit to the CZ help? It states that it can control both leading and trailing independently. It seem that there aren't any piggyback ECU that has the ability to control the leading and trailing ignitions without addition an addition unit like the AEM.
Old Sep 14, 2004 | 06:40 PM
rotarygod's Avatar
The Ric Shaw ecu can control both. You could add the AEM unit to Canzoomers. My concern though is that the more things you piggyback, the more things you have to control and worry about. ti is so much nicer to just have everything in one unit.
Old Sep 15, 2004 | 02:27 PM
shelleys_man_06's Avatar
Not anymore
I've heard about the strange timing split elsewhere. Why do you think Mazda did this? What would happen if there were only a fixed timing split on the RENESIS?
Old Sep 15, 2004 | 02:44 PM
guy321's Avatar
Humpin legs and takin nam
I could be wrong, but the older 1.1 CZ looks like it does not control trailing ignition, although it could.. It appears to be wired in but the dip switches are shut off. I could be wrong.
Old Sep 15, 2004 | 05:04 PM
zoom44's Avatar
shelley's im not sure but it must be related to either fuel eficiency or emissions. it doesnt make sense that they would do it for power as at times when it has less split it would be making les power
Old Sep 15, 2004 | 08:16 PM
Not anymore
Was the original design so bad at emissions they had to resort to the current timing split?
I'm with rotarygod on using a fixed timing split as part of a base fuel map. As for how to control it, I'm at a crossroad.
Old Sep 15, 2004 | 09:10 PM
zoom44's Avatar
thanks for that info jeff good to know. what is the stock split under load?
did i mention that they said there were also 4 different a/f maps? 1 for gears 1-4, one for gears 5 and 6 and 2 for when decelerating- one for when decelerating in gear and the other for when you are just coasting. no wonder the "runs out of the box" piggybacks have trouble working for everyone even if there wasnt a "mafs issue".
Not anymore
Ouch. That sounds worse when you think about it. Is that one of the drawbacks of piggyback computers? Switching to a stand-alone is my last resort.
Old Sep 15, 2004 | 10:49 PM
rotarygod's Avatar
Find out if you can. That would be good to know. I like a fixed split of 10 degrees. Any more than that and you will lose power and any less than that and you probably will too. Many of the RX-7 guys are sorely misinformed when it comes to timing split. They insist that the less split you have the more power you have. This isn't always true. When we were at Racing Beat and were listening to Jim Mederer talk, he mentioned the timing split making less power if it was too little. He also mentioned the magic 10 degree split number. zoom44 heard this too. I just looked at him and smiled when Jim said that because it confirms what I have discovered from playing around with rotary timing. If you look at Paul Yaw's website he also mentions that the 13B's run best with a fixed split of 10 degrees with a total of 26 degrees max advance. 8 degree split for the 12A engines.
Jeff, if you only advance the leading plugs, how are you decreasing the timing split? You would be increasing it since the trailing isn't increasing. This would hurt power. The only way you could decrease the split in this scenario is if the trailings were always firing first.
Old Sep 16, 2004 | 01:44 AM
rotarygod's Avatar
I found this timing map for an aftermarket ecu that an RX-7 guy is using. You'll notice that it is almost exactly what I say I like to use. The timing itself is basically the same. His car is a turbo so that will give an idea of why a map sensor is important to tuning a forced induction setup.
Total leading timing per rpm
Idle ~ 00
1000 ~ 10
1500 ~ 15
2000 ~ 20
2500 ~ 25
3000 ~ 25
3500 ~ 25
4000 ~ 25
4500 ~ 25
5000 ~ 25
5500 ~ 25
6000 ~ 25
6500 ~ 25
7000 ~ 25
7500 ~ 25
8000 ~ 25
9000 ~ 25
leading/trailing timing split per rpm
0500 ~ 15
1000 ~ 15
1500 ~ 15
2000 ~ 14
2500 ~ 12
3000 ~ 10
3500 ~ 10
4000 ~ 10
4500 ~ 10
5000 ~ 10
5500 ~ 10
6000 ~ 10
6500 ~ 10
7000 ~ 10
8000 ~ 10
Under boost the map sensor adjusts the total timing advance a little but the split remains the same. If detonation is still encountered there are 2 options. One is to retard the timing further. The other is to increase the timing split.
Idle ~ 00
25 ~ 05
20 ~ 04
15 ~ 03
10 ~ 02
05 ~ 00
00 ~ 00
2psi ~ 00
4psi ~ 00
6psi ~ 00
8psi ~ -02
10psi ~ -03
12psi ~ -04
14psi ~ -04
16psi ~ -05
18 psi ~ -06
20 psi ~ -06
It is a little more complex than this and I am leaving some stuff out but I thought you guys might want to see it to get a frame of reference. Keep it simple.
Old Sep 16, 2004 | 12:01 PM
zoom44's Avatar
yep i heard jim mederer say that and i didnt miss the smile on your face when he did either. its good to get confirmation from someone of his caliber. when i asked jim why Mazda would do it this way he just kinda shrugged- i dont think he is at the point in his testing to start figuring out the why just yet as he is still tracking all the things that the pcm does. i bet he has an idea but didnt want to just speculate.
Old Sep 16, 2004 | 06:13 PM
Not anymore
I'm aware of the fact a MAP sensor is ideal for forced induction, but wouldn't it be difficult to wire one in along with the MAF sensor?
Off-topic: I've been looking at Pro-M's blow-through MAF for the Mustangs. I wonder if something like that may be ideal for forced induction rotarys.
Old Sep 16, 2004 | 08:57 PM
bureau13's Avatar
Its kind of ironic, but over at the RX7 forum there's an on-again, off-again perpetual thread about how they want to convert the twin-turbo 3rd gens to a MAF system. Everybody wants what they don't have
jds
Old Sep 16, 2004 | 09:39 PM
Not anymore
Yeah. Either way, you have to figure out flow rates. :D
Old Dec 21, 2023 | 03:56 AM
Necoxus's Avatar
Originally Posted by zoom44
thanks for that info jeff good to know. what is the stock split under load? did i mention that they said there were also 4 different a/f maps? 1 for gears 1-4, one for gears 5 and 6 and 2 for when decelerating- one for when decelerating in gear and the other for when you are just coasting. no wonder the "runs out of the box" piggybacks have trouble working for everyone even if there wasnt a "mafs issue".
How does the ECM determine what gear the transmission is in? Is it looking at Engine RPM compared to wheel speed?
Sorry for the necro, but I find this interesting as to how to could affect the manual swap I've been driving.
Old Dec 22, 2023 | 08:44 AM
I wouldn’t trust anything on this subject from back in 2004
nice necro bump though.
Old Apr 21, 2024 | 08:06 AM
motodenta's Avatar
Yes and no
There are unknown tables in ECU ( unknown to us aka public) which vary from year to year and market to market.
The question is, does it matter? and answer is not.
over 90% of power is made by L spark plug, T other less than 10% to clean combustion. if you want to nick-picking you should add back the 3rd spark plug for less than 5% improvement.
Spoiler
j_s2000
11
Jun 4, 2006 09:38 PM
OfficerFarva
Aug 19, 2005 02:08 AM
Lock & Load
Series I Engine Tuning Forum
Jul 29, 2005 07:48 PM
BLOWN8
30
May 26, 2005 10:31 AM
Magic8
21
Oct 13, 2004 05:37 PM
