SR Air Intake
Old Sep 11, 2004 | 11:59 AM
Lschiavo's Avatar
05 Champ Car Test Driver
Exclamation SR Air Intake
I recently bought the SR air intake. After installing it and running it I feel the car is not right. THe car feels stronger in the low gears but when I accelerate the car seems to starve for fuel for a second before going. Also, If I keep my pedal depressed at mid throttle, the car would just shake like if I were banging the gas pedal. THat also happens when I use the cruise control. Anyone using this intake?? Any suggestions?
Old Sep 11, 2004 | 02:09 PM
RPIRX-8's Avatar
Apexing at Oak Tree
How long have you had it installed? Did you disconnect the neg batt terminal when you installed it? The ECU prob just need some time to learn.
Old Sep 11, 2004 | 03:09 PM
Lschiavo's Avatar
i did not disconnect the neg bat terminal. I just installed it last night... Any procedure after installation?
I also got the engine light on in my dash. It is flashing... I already did the 20 times in 8 sec in the brake pedal, but light still there...
Old Sep 11, 2004 | 03:21 PM
Mugatu's Avatar
Even My Dog Searches
welcome to the wonderful world of troublesome intakes for the RX8.
Old Sep 11, 2004 | 10:57 PM
leegina's Avatar
The brake light test will not do anything for the light disconnect the neg battery terminal for about 30-45 minutes and pump the brakes with it disconnected to drain any juice left in the ecu and reattach the neg and start it up. Check for any leaks in the connections also.
Old Sep 11, 2004 | 11:02 PM
Overport's Avatar
Overport
alot of people have problems at first with air intakes for their rx-8.
Old Sep 12, 2004 | 03:58 AM
Lschiavo's Avatar
at first? Do they fix themselves over the time? What can I do? I am thinking of putting the original back in the car.
Old Sep 12, 2004 | 04:02 AM
TSi RX-8's Avatar
1/4 mile or autocross ?
lmao an air intake causing problems?? WTF!!? lol
Old Sep 12, 2004 | 06:37 PM
Fanman's Avatar
There is a thread about this. Try doing a search, it is a really long thread. I think it was due to the way the unit is assembled, it can be hard to not fold up the seal around the K&N cone. Results in a bad hesitation & idle. The leak causes the MAF readings to be all over the place.
Old Sep 12, 2004 | 07:31 PM
Funny thing I was at Seven Stock and talked to the owner of SR Motorsports.
He said he has never had a problem. It seems to be very quite too.
Call him if you have a probelm, but disconnect to battery to fix the flashing light problem.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
vapor2
Jul 9, 2016 07:35 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Vedivan1
Sep 18, 2015 12:39 PM
