Transmission fluid help...comeon mazda
Old Jul 1, 2004 | 05:29 PM
rotarymagic's Avatar
Hey everyone, please advise-
I called Mazda because I want to change the transmission fluid in my 6-speed. They asked if I wanted a flush or a drain and fill.
I asked them how they flush the tranny and they said that they flush the whole system with automatic transmission fluid. Is this correct? Should they flush a manual trans with auto trans fluid?
Also, they said a flush is $140 and a drain and fill is $70. That seems expensive, but i don't want to do it myself, can I trust Mazda, is the question.
Also, does anyone know if they will have Redline MT90 synthetic or an equivalent at the dealer to use? Or would they only have natural trans oils?
Thanks everyone
Old Jul 1, 2004 | 07:32 PM
x3dfxWolfeman's Avatar
Quiet, fignuts!
It sounds like maybe the tech may have misunderstood or missed that you had a Manual tranny; but, that said, how many miles do you have on the car? Is the transmission fluid looking severely discolored or dirty?
Old Jul 2, 2004 | 03:11 AM
Nubo's Avatar
Lubricious
Sounds like maybe just interested in replacing the fluid with the red-line stuff. I've ready many reports that it results in a significantly better shifting feel. I'm going to try it myself. Have never heard about flushing a manual transmission though.
Old Jul 2, 2004 | 08:35 AM
fordracing19's Avatar
you talked to an advisor that didnt know what they were saying. We have 1 of those. It's just a drain/fill. We do not carry and syn. oils at our dealer.
Old Jul 2, 2004 | 08:37 AM
mysql101's Avatar
Where would you guys recommend going to get the tranny/diff fluids changed?
My mazda dealership is telling me they only use the mazda fluids, so no redline.
Old Jul 2, 2004 | 08:58 AM
crazy4h20's Avatar
My dealer has told me I can bring my own fluids and they will do the work.
Old Jul 2, 2004 | 11:10 AM
I have 12,500 miles on my 8. Some tend to believe the trans fluid should be changed out early in a cars life, due to the initial wear of the trans and such. I tend to agree with this assessment, therefore I will get it changed.
Maybe I should bring the car somewhere else? Or just bring in synthetic transmission oil?
So, there is no way to flush a manual trans? OK, the guy must have been confused when he said that. It is interesting though, becuas when he said that I replied: "I have a manual 6-speed, would you still use the automatic trans fluid to flush. He then said, umm... they would use whatever they need for the job.
Old Jul 2, 2004 | 11:12 AM
Just to confirm, Redline MT 90 is the correct fluid for the 8, is it not?
Old Jul 2, 2004 | 12:02 PM
Nemesis8's Avatar
Bigus Rotus
I had my 6MT changed because I was experiencing hard shifting from 1st to 2nd. The ticket says FP-NUMBER XY-75W90-QFEHP with a description of OIL-RR 807025. I'm not sure what this is, but my tech told me it was synthetic. Anyone know what these numbers are?
Old Jul 2, 2004 | 02:44 PM
jdl's Avatar
jdl
just jd.
diy...
You might just want to change it yourself -- it's surprisingly easy
Old Jul 2, 2004 | 08:31 PM
bgreene's Avatar
Time of your life, kid...
If you're doing it yourself, just make sure you get a piston-type fluid transfer pump (all the ones I've ever seen are red). It's worth the extra $$$ compared to the bulb-style siphon pumps.
the cheapo-pump I picked had a tube with an inner diameter of probably 1/16 in. I managed to get a half-quart of Differential gear oil through it in a little over an hour (i just have to learn some lessons the hard way, it would seem....)
Old Jul 3, 2004 | 12:37 PM
Kwullen's Avatar
Yeah, they mean buy your own Redline and take it to them.
The other good tranny oil is Valvoline Synthetic Gear Oil - 75/90.
Old Jul 3, 2004 | 12:55 PM
Nemesis8's Avatar
Bigus Rotus
I think I'll go down and talk to my tech about it, he is pretty good at helping me with my 8.
Old Aug 1, 2004 | 04:16 PM
shaunv74's Avatar
Power!!
I just picked up some Lucas 80/90 GL-5 transmission oil. (didn't have any redline) Does anyone know if this will be okay to replace the transmission oil with? The manual says GL-4 or GL-5 75W90. I'd like to make the 1-2 shift a little smoother.
Old Aug 1, 2004 | 09:21 PM
red_rx8_red_int's Avatar
OK, I'm a newbie to performance cars. I looked at howstuff works several times now and think I have a good understanding of how an MT and clutch work. Are all gears and shafts bathed in oil, or is it just where the shafts are supported?
Old Aug 2, 2004 | 05:11 PM
rx8cited's Avatar
Senior Member
Here's a thread to help: DIY: Transmission and Differential fluid replacement . You don't need to spend no money on no stinkin' pump.
rx8cited
Old Aug 12, 2004 | 10:35 AM
Frank Patrick's Avatar
any info on automatic transmission change procedures?
Old Aug 21, 2004 | 10:19 AM
BOB9995's Avatar
People
A place called GRIOT'S Garage has a great one, item #44480, at www.griotsgarage,com.
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
DJclever
Sep 6, 2015 10:51 PM
CRAZ8
Jul 22, 2015 10:02 AM
