jumping wires to make fuel pump run on high and low mode?
Old May 7, 2012 | 07:58 PM
bumblebeerx8's Avatar
Rear Mount GT35R
I just finished up my return fuel system. Is there a way to pressurize the system without starting the car to check for leaks? Also is there a way to put the pump into low and high mode to check pressures of each?
Old May 7, 2012 | 08:03 PM
Brettus's Avatar
Boosted Kiwi
yes - turn the ignition on .
think you can cross the wires to achieve this no problem - don't ask me which ...
Old May 7, 2012 | 08:17 PM
Rear Mount GT35R
From what I have read/ heard the car do, with the ignition its only a few seconds the pump is on, that would not work to show pressure because of the return. I could be wrong. I seen about crossing wires but still not sure which either
Old May 7, 2012 | 08:36 PM
The pressure should stay up after the key is turned on...if the regulator is working properly it will bleed down slowly. There is a spec for this in the FSM.....
You can easily "jump the pump" with a section of wire on the fuel pump test plug in the fuse box ( I think there is one there )
Old May 7, 2012 | 09:04 PM
Rear Mount GT35R
right now i have the screw on top of the regulator backed all the way out. I really did not have a ton of time to mess with this part.
Old May 8, 2012 | 09:50 AM
olddragger's Avatar
there is a jump connector in the engine fuse box.
Old Aug 8, 2012 | 12:43 PM
FazdaRX_8's Avatar
so you make a jump connection in the fuse box and your in high mode?
which relay do you swap with a direct link?
Old Aug 9, 2012 | 08:07 PM
Nemesis8's Avatar
Bigus Rotus
Can't you also unplug the resister and jump the plug to force high speed mode?
Old Aug 12, 2012 | 01:03 AM
FazdaRX_8's Avatar
so just remove the resister and make it a short?
Shnifty
23
Dec 18, 2015 12:49 PM
harithac
Jul 31, 2015 09:57 PM
dbarber
Jul 25, 2015 01:34 PM
stickmantijuana
Jul 19, 2015 10:33 AM
