What hose goes here?
Old Apr 14, 2012 | 06:10 PM
anoble1's Avatar
2004 RX8 Owner
Guys, I need some help! I have 2 spots for hoses to hook to the motor. I have no clue where they go.
photo 1 is on top of transmission or near it on top/
photo 3 is right under the headers
photo 2 is the passenger side of the car.
Please Help!!!!!!!
Attached Thumbnails What hose goes here?-photo-1-.jpg   What hose goes here?-photo-2-.jpg   What hose goes here?-photo-3-.jpg
Old Apr 14, 2012 | 07:44 PM
Ist one is a coolant line that goes to the small hose on the front of the engine under the thermostat area ( actually I think this is the one that goes to the throttle body and then from the throttle body to the area described above
2nd one looks like the VDI VAc line...goes to one of the solenoids on the back of the UIM..near where picture one is ....think it is the bottom one??....
3rd one ( got it wrong...Jet air tube it is )
Old Apr 14, 2012 | 08:09 PM
Jon316G's Avatar
Grasshopper
3rd pic is the port for the "Jet Air Fuel Mixing" system.
The hose that connects there goes back to the intake on the accordion tube.
Old Apr 14, 2012 | 10:33 PM
anoble1's Avatar
2004 RX8 Owner
So the Jet Air Fuel Mixing goes from the place on the headers, all the way to the accordion? That's a long hose. I assume it's the long hose on the accordion. See pict.
Old Apr 14, 2012 | 10:40 PM
anoble1's Avatar
2004 RX8 Owner
And the 1st one goes from the accordion to the back of motor to this picture?
Old Apr 14, 2012 | 10:54 PM
That is a coolant hose
...don't want to hook it to the intake
If you don't want it connected to the throttle body ( trust me you don't unless you live in the arctic )...hook it to the smallest of the tubes that come off near the lower radiator hose connector that has the multi-tubes coming out of it...below the thermostat housing
You will have 2 hoses in your stuff that need to be joined with a coupler if you are going to bypass the throttle body
Old Apr 14, 2012 | 10:56 PM
The long one with the metal bracket is for the Jet air....the other one is the tube for the OMP atmospheric line I think...or the crank vent line
The three lines from the intake bellows are the Jet air...the crank vent ( depending on the year...slightly different routing) and the vent for the OMP that is incorporated into the black spacer under the primary injector bolts
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Evan Gray
Nov 24, 2015 01:00 AM
