Fuel Injector Male Connectors
Old Mar 20, 2012 | 11:32 AM
BlackStealth's Avatar
I'm about to change out the injectors in my car again for aftermarket one's, and since the connectors are different, I would have to splice or cut the wires so the retaining clips (connectors) will fit with the harness.
So I'm just wondering if anyone knows a place that sells injector clips with a male connection to the stock retaining clips for a clean install with no soldering and an easy disconnect if I choose to go back to stock
Old Mar 20, 2012 | 11:34 AM
Oh boy. Atpturbo sells the connectors.
Old Mar 20, 2012 | 12:22 PM
you might try to see if you can de-pin from the OE connector and then slide them in to the alternate one, just depends which one you will be using and if the pin type/size is close enough to each other, most sell direct plug & play adapters for all the popular stuff too
Old Mar 20, 2012 | 12:33 PM
You can buy adapters for almost anything to almost anything....
try Ballenger Motorsports I have had good service from them in the past
Old Mar 21, 2012 | 07:33 PM
Can someone please confirm which one I would need? I believe it's the Denso type, but I still can't find any male connections - or maybe I'm blind?
http://www.bmotorsports.com/shop/ind.../cPath/109_175
Old Mar 30, 2012 | 01:43 PM
BUMP!
OR any of these connectors are proper for the rx8? I really want to be sure before purchasing and any help is greatly appreciated
http://www.atpturbo.com/mm5/merchant...egory_Code=FUL
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
DeltaJ802
Sep 29, 2015 01:20 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Learners_Permit
Sep 27, 2015 07:38 PM
