NW RX-8 Forum Serving WA, OR, ID, AK
Go point bt1
Old Mar 11, 2012 | 03:27 PM
ANIBALRX8's Avatar
Cool Go point bt1
GO POINT BT1 is a bluetooth obd2 code reader for iPhone and I believe it works with android too.
I just got my wife a jeep grand cherokee 05, since it use I did my normal rooting which is to clean the engine in cause it has a leak. SO the next day the jeep's engine is shaking and the engine light came on, so am thinking no problem its that one of the spark plug is still wet, but three days later its still doing it. So I got the GO POINT BT1 from Radio Shack $89, I did look online but it was like $100 to $120, so good price I hook it up and download the two app, and it works great p0306 misfire cyl #6, which is ether spark plug, coil or cable. So part of my rooting is oil change and spark plugs, so am keeping the oil do to the fact that it was dome a month ago, so I change the spark plug and I found #6 still wet, so I move it to number #2 to make it easy to change if I need to. I clear the code with the GO POINT BT1 and I went for a drive sense the engine was very smooth and no check engine light, it was pulling very nice and hard but 1/2 mile check engine light come on and the engine started to shake again, so I pull over and look at my iPhone and it had p0302 misfire cyl#2 misfire, so the next day I got the coil replace during my lunchtime about 15min and clear the code. started her up, engine was smooth drive her around the block and it pull very hard and no more check engine.
So am very happy with this GO POINT BT1 that I should share with all of you!!!
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Brokegang
Jan 3, 2016 12:45 PM
