Little too much oil. Can I remove some?
Old Feb 6, 2012 | 04:45 PM
Vic-Viper's Avatar
Just put some oil in and did my math wrong. I haven't turned the car on yet. Any suggestions on the easiest way to remove some oil? I don't have access to a ramp without driving somewhere.
Here is where my oil line on the dip stick is.
Old Feb 6, 2012 | 04:47 PM
wrightcomputing's Avatar
Made in England
I would just jack it up and unscrew the drain pug let a little oil out then put the plug back in. Your going to get covered in oil but better then blowing a seal
Old Feb 6, 2012 | 05:02 PM
Grace_Excel's Avatar
Charles Bundy
I don't exactly see how it will blow a seal? Worse I think will happen is a blow-by in the intake and dirty up your MAF sensor messing up the readings. Unless you have an oil catch can, I would try to not redline it as much causing the oil to go into your intake manifold(follow the hose connected from your filler cap and you'll see what I mean). Besides, that is what the OMPs are for!
Old Feb 6, 2012 | 06:15 PM
It will be fine there.......
Old Feb 6, 2012 | 09:32 PM
abrankhalid's Avatar
Jango
I did the same thing last oil change . Just made sure i did not give it the beans until the level had come down a bit. I think you should be fine with that.
Old Feb 6, 2012 | 10:38 PM
shadycrew31's Avatar
WENTGERMAN
Just drain some out its not rocket science.
Old Feb 9, 2012 | 08:39 PM
swiftnet's Avatar
A fluid vac is a great investment. You can suck out some oil or all of it.
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
