04 rx8 problem not sure what it is
Old Jan 17, 2012 | 09:41 PM
TheNewGuy2's Avatar
Mechanic says either the exhaust leaks or its the cats? What should I do? Please dont flame me I'm new to the club. I've read a lot of stuff on here but still have a lot to learn.
Old Jan 17, 2012 | 09:52 PM
RX8Soldier's Avatar
Time for boost...
How should we know what the issue is? You haven't even given us any sort of description!
Mileage? Modifications? Check Engine Light (CEL)? Maintenance history? etc etc?
Oh, and have you searched, before making this thread?
Old Jan 17, 2012 | 10:59 PM
StealthTL's Avatar
Metatron
I'm guessing your cats are exhausted.
Or leaking.
Really, get a clue and some data - does it start? is there a noise? is it on fire?
Hard to diagnose without some history.....
Old Jan 18, 2012 | 06:56 AM
Joe-the_tattoo_artist's Avatar
Got Ink?
:rol lingla
That is the funniest comment that I've read in a long time.
Old Jan 18, 2012 | 07:17 AM
TheNewGuy2's Avatar
2nd motor in car. New motor has 40k miles. No problem starting. New plugs. Wires need replacement. Check engine light comes on every once and a while
Old Jan 18, 2012 | 07:43 AM
paimon.soror's Avatar
are you grabbing the code when the CEL comes on?
Old Jan 18, 2012 | 07:47 AM
200.mph's Avatar
FULLY SEMI AUTOMATIC
how about your coils? failing coils can cause a cat to go bad which can cause an engine to go bad. more info is needed. the cat is warrantied but you might be out
Old Jan 19, 2012 | 09:02 AM
TheNewGuy2's Avatar
How many miles after do I need to change coils and plugs/plug wires?
Old Jan 19, 2012 | 09:10 AM
Silver_Surfer's Avatar
I4NI
Your only problem is the CEL? You should be able to hear/smell an exhaust leak.
Old Jan 19, 2012 | 11:03 AM
usnidc's Avatar
2008 40th Anniversary
How many total miles on car?
next time the CEL comes on, go to an Autozone and have the code pulled.
Could ba an 02 sensor, or a misfire from a bad coil. hard to say without the code.
Old Jan 19, 2012 | 10:54 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Have the code read when it comes on the next time. That is the only way to diagnose the problem with your car. Keep us updated.
Old Jan 20, 2012 | 11:00 AM
TheNewGuy2's Avatar
The CEL comes on and before I get a chance to take it to get pulled it goes off. Idk it turns on and off. Never stays on long. Thanks guys
Old Jan 20, 2012 | 11:28 AM
It still is in the memory chip.
Read it.
Cel flashing is common. It's a misfire.
Car runs too rich from factory.
If you had an exhaust leak after the O2 sensor you should be okay. Before the sensor the the car ECU would cause all sorts of problems and a cel as it try's to compensate for wrong fuel mixture.
Any leak can be heard and or smelled.
ladnarf1
Apr 29, 2021 11:53 PM
Skyl3r
Dec 2, 2019 04:51 PM
SIllver
Aug 1, 2015 07:34 PM
Belalnabi
Jul 22, 2015 04:50 PM
Belalnabi
Jul 17, 2015 07:48 PM
