Smoke Under the hood
Old Dec 28, 2011 | 03:46 PM
dsire4u's Avatar
SS RX8
hello guys
i have 04, 110000km rx8
recently i was having some issues with low idle and vibration
I knew it was time to change my coils/plugs/wires
so I changed all my coils/plugs/wires and even did oil change this morning.
When I jack up the car to drain my oil, i noticed little wet spot underneath my car.
I smelled it and it was my coolant. Leakage wasnt severe, it was almost dry. I guess its a small leak.
So i added some coolant, finished doing all the work
and went out to test drive.
I felt like my engine was back to normal and running great
I did some hard driving for 3~5mins and came back home.
When I was entering my garage, I noticed smoking coming out under my hood. Smoke comes around my coolant tank. smells like coolant.
My coolant temp gauge, and engine oil temp gauge is normal
I let my car be a bit (smoke stopped) and went to gas.
As I came back home, there is smoke again around and beneath the coolant tank.
But I checked my coolant level before and after, coolant level stayed the same
CEL came on as I was driving to gas station
Since I dont live in US, there is nowere I can get my CEL checked for free.
Last time, Mazda charged me 60 dollars which is rip off.
I cant afford to pay 60 dollars right now,
I dont know what my problem can be,
Please help,
Old Dec 28, 2011 | 04:14 PM
Likely need more oil...3 litres isn't enough for an oil change is it?
There are some things to check for the coolant thing. At 100K+ and 7 years I would be looking at rad and heater hoses. Mine were very shot from all the track driving I do at 4 yrs...Also the rads can develop leaks in the plastic tanks as well.
If the coolant seals were leaking you would normally see white sweet smelling smoke and the car would be hard to start..or you would have coolant in the oil
Old Dec 28, 2011 | 04:29 PM
dsire4u's Avatar
SS RX8
Hello, Dan
yeah, I ran out of engine oil, so when I was gasing, i bought another 2 litres of oil and added a litre in.
my engine oil light is gone now.
My car starts like right away. have no hard time starting.
I knew my coolant is leaking slowly, I'll def check my coolant tank/hoses for the leaks.
can coolant leak develop CEL?
Old Dec 29, 2011 | 10:29 AM
xexok's Avatar
What about your engine oil level, whats it at? The light is only to tell you of a big problem with the oil not to tell you when or how much to fill it. Just to make sure it is actually full and not still low.
You may consider buying your own scan tool, you can get one for cheaper than Mazda wants to charge you to read it once. Getting the cel read would be a huge help.
Old Dec 29, 2011 | 11:53 AM
warbick's Avatar
I am having a similar issue as the OP, and I also have an 04, although with under 50k miles. It happened the other day, and hasn't happened since. The smoke was indeed sweet smelling.
You say the coolant seals could be leaking, can you point me in the right direction, where are those exactly?
Old Dec 29, 2011 | 11:56 AM
Inside the engine between the aluminum rotor housings and the cast "irons"
If you have a coolant seal leak you need a rebuild or a new engine...no way around it
WranglerFan
May 31, 2022 07:51 AM
Azki23
Jun 27, 2018 03:48 PM
poacherinthezoo
Aug 3, 2016 11:01 PM
pjwermuth
Sep 28, 2015 11:36 PM
Rx8_412
Sep 24, 2015 08:51 PM
