Rolling start to bring flooded engine to life?
Old Nov 24, 2011 | 02:08 PM
Mugatu's Avatar
Even My Dog Searches
can anyone confirm the push/pull start method for bringing a flooded engine back to life? It would seem that wouldn't work because the rolling wheels would basically just replace the starter motor in theory, and the starter motor isn't getting the job done.
However, this advice comes from Rotary God, so I assume it has some real world experience behind it. Can anyone confirm this will work?
Right now, I have what I believe is a flooded engine. Won't start, but will turn over. Replaced the original battery, which is now almost 5 years old. Engine will crank but won't start.
I tried the pedal to the floor for 10 seconds, then off, then regular start. no go. I'd like to give the push start a try if it's a sure thing. If not, it's off to the dealer I guess.
Old Nov 24, 2011 | 03:04 PM
Twisties's Avatar
Yes it will start if you have a manual, but there is a reason you flooded. How old are the plugs coils and wires
Old Nov 24, 2011 | 03:25 PM
Twisties's Avatar
Also it may seem like the deflooding procedure isn't working, but it took me almost 2 days to get mine to start. But then again I replaced the plugs and wires, my coils were only 10k old. Once they get close to 30k they start to fail.
Old Nov 24, 2011 | 03:36 PM
Arca_ex's Avatar
BECAUSE RACECAR
Pull starting is the easiest way to start a flooded engine. The reason is because it'll turn the motor faster than the starter could ever hope to.
Old Nov 24, 2011 | 03:46 PM
Pull starting will turn the motor over fast enough that the compression will increase more than enough
At 3K rpms you could start a motor with no apex seals...wouldn't run well...but it would run as long as you kept the rev's up. I drove a car with a blown motor ( zero rear rotor compression and 50's front) for 50 miles after pull starting it
Old Nov 24, 2011 | 04:37 PM
zoom44's Avatar
pull it mugatu and have a great thanksgiving. sorry cant be there to help.
Old Nov 24, 2011 | 04:42 PM
The factory deflood procedure can take forever. If you can push start it that is the way to go. I have done it twice when other members have flooded their cars, it works like a champ.
Old Nov 24, 2011 | 06:53 PM
zoom44's Avatar
NOOB!
Old Nov 24, 2011 | 09:08 PM
Mugatu's Avatar
Originally Posted by zoom44
NOOB!
yep, going on 9th year owning an 8 and I finally did it. Certainly feel foolish. At least I searched first.
Old Nov 24, 2011 | 11:13 PM
Yeah I flooded mine after owning it many years as well. I was wearing wet flip flops and my foot slipped off the clutch and I stalled it when it was cold. Hopefully the BHR kit will keep that from ever happening again.
Old Nov 24, 2011 | 11:22 PM
Grace_Excel's Avatar
Charles Bundy
Would have been a waste of your Thanksgiving dinner had you not searched for this method. Works like a charm, even if my car's not flooded, I do it parked downhill just for the heck of it.
Old Nov 24, 2011 | 11:39 PM
Wtf, mugatu epic fail
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
delicious_dallan
Jan 17, 2020 09:17 AM
harithac
Jul 25, 2015 04:21 PM
thedragonrotar
Jul 22, 2015 08:46 PM
