Rebuild Turbo or Replace
Old Aug 28, 2011 | 12:42 AM
dpenta13's Avatar
I am getting together all of the pieces needed to do the Greddy turbo kit on my 07 RX8. I picked up the kit used and I am debating on sending out the Greddy T618Z for a rebuild (planning on sending to Turblown) or just replacing it all together. I would love to do the Mazda Maniac upgrade kit, but it is out of my budget, I'm only 18. Does anyone know of another turbo that would fit on the greddy manifold and give me equal or better numbers than the T618Z. I also don't want to be a cheap ***** and buy a piece of ****. If you guys feel it is worth it to pony up the money for the MM turbo... I will put the install off a few months and go that route. T618Z Turbo worth rebuilding?
Thanks Guys
Old Aug 28, 2011 | 12:47 AM
Brettus's Avatar
Boosted Kiwi
It's worth rebuilding for sure but it will cost over 1k for an upgrade to a larger wheel through BNR (recommend 50trim ) and only an extra k for a much better turbo . No brainer in my book if you can afford it .
Old Aug 28, 2011 | 01:09 AM
dpenta13's Avatar
Thanks for the response.
Also, does anyone have any tips on removing the Greddy turbo from the Greddy manifold.
I have 3 of the 4 nuts off but i cant get a wrench or socket on the last one. And the whole assembly is off of a second motor that i purchased so its not in the car. It is positioned between the turbo and manifold... and wedged in by a line coming off the turbo.
Old Aug 28, 2011 | 01:15 AM
dpenta13's Avatar
And thanks for letting me know about the BNR upgrade... looks like a great option for the money. To be honest i dont believe i have heard about that at all. Thanks Brettus
Old Aug 28, 2011 | 02:12 AM
Brettus's Avatar
Boosted Kiwi
Umm - think I was not clear enough there . The no brainer part is the MM upgrade turbo - next best is the BNR upgrade . At 1k more the MM upgrade would be my pick but the BNR is worthwhile as well.
Old Aug 28, 2011 | 07:54 AM
dpenta13's Avatar
Ok, I get it now... thanks for the help brettus. And do you or anyone know how to get the turbo off the manifold? Seems much harder than this should be.
Old Aug 28, 2011 | 02:47 PM
Brettus's Avatar
Boosted Kiwi
I have done it a few times and had no problems . Just having the right tools is the key . You did remove the oil drain line before trying to undo the nut ?
Old Aug 28, 2011 | 07:58 PM
dpenta13's Avatar
I removed one of the bolts on the oil drain line... and tried to rotate it. The other bolt on the drain line is wedged against the nut I'm trying to get off. I will try to work it out next time I'm at the shop... if I cant do it I will post some pics
Old Aug 28, 2011 | 08:02 PM
Brettus's Avatar
Boosted Kiwi
That bolt on the drain line just needs to be slackened off and then the drain will pull off as it has a slot on that end .
rotorocks
47
May 11, 2016 03:23 PM
uZu
Dec 30, 2015 12:35 PM
HMSS013
Aug 28, 2015 03:08 PM
MolecularConcept
Aug 9, 2015 04:46 AM
thedragonrotar
Jul 22, 2015 08:46 PM
