Help Rebulding Greddy T618Z Turbo
Old Jun 25, 2010 | 10:29 AM
monte66's Avatar
I need to have my turbo rebuilt. I have some questions if anyone knows anything. First off is it really a pain to do? If I do not do it myself, I live in FL does anyone know where I could send it to be rebuilt cheaper than Greddy? Also, is there a better even chaper way to go than rebuilding this turbo. I have researched some flaws with is design and the up grade kit is a sick 1900 which is not in the budget.
Thanks guys
Old Jun 25, 2010 | 06:20 PM
BigTurbo74's Avatar
How much does Greddy charge? If it is a journal bearing turbo send it to these guys.
http://turblown.net/store/index.php?productID=70
Give Elliot a call at Turblown, he is very knowledgeable with turbo upgrades/options.
Old Jun 26, 2010 | 10:16 PM
monte66's Avatar
Thanks greddy wants 700. But my big question is all turbo have gone to ball bearing internals and I and to see if I can convert this one as well. This turbo was not designed well.
Old Jun 29, 2010 | 01:11 AM
Turblown's Avatar
Boostin'
What is wrong with the turbo that is requires a rebuild? It would take a LOT of money to covert it to BB, not really a feasible option. If the core is in good shape we charge $300 + return freight..
Old Jun 29, 2010 | 02:36 AM
laythor's Avatar
I zoom therefore I am.
isnt the rebuild kit 60 bucks on ebay?
Old Jun 29, 2010 | 02:51 AM
Brettus's Avatar
Boosted Kiwi
How long did you get on the turbo ? The right sized restrictor makes a big difference
I'm at 22,000 miles and running strong
Old Jul 3, 2010 | 03:10 PM
Z0oMzo0m's Avatar
The turbo has less then 10k miles on, actually we started to pull it out today, but got hung up on the 4 bolts from turbo to the manifold..
We sprayed them well with pb blaster, well let it sit over night and try again i the morning. But other then that is should drop down. Charles i talked to you and got "restricted ordered" .062.
I figured since we were doing this and oil has allready gone into the turbo we might as well pull it out to double check everything. At least get it cleaned out if checks out ok. why do a job again right?
If we cant get the bolts from turbo to manifold off, is there another way to drop it at once, with it all together? doesnt look promising..
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
jDt!
Oct 2, 2015 04:04 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
