cold start slight misfire
Old May 31, 2010 | 06:11 PM
sgt_slap_a_hoe's Avatar
On a cold start my car has a slight misfire, while driving no misfire at all. Starting it through out the day after the cold start no misfire.
What do you guys think this could be? I know it's not the coils because if the coils were bad then it would misfire randomly or when im driving.
Just changed my spark plugs yesterday.
Thanks in advance...
Old Jun 1, 2010 | 04:06 PM
anyone?
Old Jun 6, 2010 | 06:15 PM
Faxie's Avatar
I think mine has the same too.
Happened after changing the plugs and wires... Wires are on tight...
Got no clue...
Old Jun 7, 2010 | 10:03 AM
anyone have any info on this?
Old Sep 3, 2010 | 08:34 PM
Faxie's Avatar
I can't find any other topics about this....
I changed the wires for Racing Beat ones, new NGK sparks, and the ECU was flashed.
The car starts fine, but just before the engine comes to life I can hear 1 or 2 clicking type of sounds.
Compression is fine and the wires are securely attached to the plugs.
Old Sep 3, 2010 | 08:50 PM
Our cars are pig rich.
You are experiencing plugs with too much fuel.
Normal.
Old Sep 3, 2010 | 08:57 PM
Faxie's Avatar
Then why didn't it happen before? I've replaced my coils a year ago, replaced the plugs 2 times, new battery, and I have never experienced that sound before...
Old Sep 3, 2010 | 09:01 PM
Because the plugs slowly build up excess fuel and carbon and become fouled.
Old Sep 3, 2010 | 09:52 PM
Faxie's Avatar
It started with brand new plugs.
Car runs fine btw. Smooth idle, WOT to redline is smooth as well, no power loss.... only the cold starts are strange...
Old Sep 3, 2010 | 11:38 PM
04Green's Avatar
Moder8
Clean the MAF. Link in the $100 thread below. You did not say what year, but if you changed the plugs, it is old enough to do the MAF. You will be surprised the difference it can make if it is dirty.
Old Sep 4, 2010 | 04:12 AM
Faxie's Avatar
I clean the MAF and throttle body on a regular basis
Old Sep 4, 2010 | 07:33 AM
04Green's Avatar
Moder8
Hm, That is usually the easy one.
More data?
Year?
Description of misfire. Is it one pop every second or so for a few seconds? Does the car shake or is it more something you hear?
Is the clicking sound a chirping sound, like someone stepped on a small bird? Do you know if the coils were the new "B" coils, or even better, BHR?
Old Sep 4, 2010 | 12:51 PM
Faxie's Avatar
2005 Shinka. The car starts normal, but just before the engine starts you can hear one or two clicks. (click - click - vroom :P ) I'm not sure it's a misfire. Idle is butter smooth, car runs great, standard Mazda coils.
The clicks aren't chirping sounds. Just, well, clicks.... and you never hear them again, only on the cold start.
I think i'm gonna detach the Racing Beat wires and check them.... maybe that's the problem...
Old Sep 4, 2010 | 02:05 PM
04Green's Avatar
Moder8
any way the clicks are and arcing sound? Like the spark is going someplace else than the plug?
Old Sep 4, 2010 | 05:59 PM
VashGS's Avatar
Zoom Zoom Addict
Misfire? You sure it's not a blown motor mount. The coils have over 30,000 miles or 6 years? Replace them.
Old Sep 4, 2010 | 07:23 PM
Faxie's Avatar
Explain how a bad motor mount is gonna cause misfires? Replaced the mounts 2 weeks ago as it happens, because of a slightly bad idle.
The current set of coils have 10k miles on them.
One more time: At first the car started just fine. Then the ECU was flashed to the latest version, plugs were replaced, wires replaced with RB ones. All other factors (gas, climate) stay the same. And then all of a sudden the clicks started.
It would seem strange to me that the plugs or wires are bad, because the car runs great. Idles great, revs great, no power loss, no pinging, smooth acceleration, good response.
It's just the engine start that annoys me. There must be some kind of explanation for it.
Old Sep 4, 2010 | 07:30 PM
Faxie's Avatar
Could it be a click from the starter by any chance? Like it disengages incorrectly or something....
Old Sep 6, 2010 | 03:30 PM
Faxie's Avatar
Update:
I have recorded the sound with my phone. Low volume, but you can clearly hear the clicks.
http://members.ziggo.nl/faxie83/Memo.amr
Old Sep 9, 2010 | 07:36 PM
Faxie's Avatar
Anyone?
Old Sep 10, 2010 | 06:22 AM
rblackx8's Avatar
rblackx8
Sounds like a starter isn't coming off the flywheel completely.
Old Sep 10, 2010 | 06:23 AM
rblackx8's Avatar
rblackx8
Well not coming off but maybe still tryin to turn it.
Old Sep 10, 2010 | 01:09 PM
Faxie's Avatar
Ok, i'll check that out. But then why would it work just fine when the car is still warm?
Jaco Greyling
Jan 6, 2019 08:39 AM
IamFodi
Series II Interior, Audio, and Electronics
28
Oct 31, 2018 06:37 AM
Redheddude222
Aug 24, 2015 09:14 AM
madrotor
Jul 26, 2015 12:06 PM
dbarber
Jul 25, 2015 01:34 PM
