insulated oil pan
Old Apr 1, 2010 | 11:56 AM
olddragger's Avatar
insulated oil pan
Well as the title says---i insulated my oil pan. Why?
I have thought for awhile now that the oil pan we have is overcooling. The pan is in a direct stream of air, its shallow and thin. I see a rapid cooling of the oil in the pan after parking for even a short while.
I was tried of the white milky stuff and was having trouble getting my oil temps up without blocking the coolers.
It worked. No more white stuff.
Temps are not any higher--but the oil stays warmer much longer after parking and it also seems to warm faster?
All subjective i know. I didnt do it in a scientific way for posting. Should have.
But Its easy to do and easy to remove if you want.
Thought it may be something for others to think about
The 09 removed the oil pan (made it larger with a part near the header??!!) from direct air flow by adding that protective plate.
Maybe i should just get that plate?
OD
Old Apr 1, 2010 | 12:01 PM
Easy_E1's Avatar
Old Apr 1, 2010 | 12:40 PM
the new plate on S2 is for improved aerodynamics ... not trying to "keep the oil pan warm" ...
Old Apr 1, 2010 | 01:00 PM
alnielsen's Avatar
OD, didn't you perform the Mazmart oil pressure mod and it increased your oil temps. I can see this as being usefull for us during the winter in the Great White North. But, for year around use? It could also cause a clearance problem.
Old Apr 1, 2010 | 03:48 PM
olddragger's Avatar
I know yall think I am an idiot ----but i am an idiot having fun.
Yes i installed the regulator mods and yes temps did slightly rise--especially from cold start up.
I just dont think an on the road oil temp of 160-170 is hot enough. (I am getting that on a 70F day) after driving 20 miles I can then park and turn the car off ---come back in 5-10 minutes and the oil temps will be less than 100F on start up. Coolant will be warmer than that. Hell at Road Atlanta a few weeks ago with ambients in the high 50's my oil temps never got over 180F!
I dont think the oil is getting hot enough.
The oil is rapidly cooling when the engine is off. With the condensation problem some are having i wondered if that was a good thing? Rapid cooling is sometimes not a good thing?
Now the 09 oil pan is bigger by a little--closer to the exhaust header (why--they could have designed it differently) and the plate over it does help air flow and offer more protection--but could it also play a role is keeping the oil pan warmer--that could fall in line with putting part of the pan near a heat source couldnt it?
It doesnt really cause a clearance problem as i just used some hard foam insulation for now.
adds maybe 1/2"?
Call me crazy---but some need to question and wonder about things more. I may be wrong totally and thats Ok--cause i have still learned something. Like i am really really stupid for thinking that
Old Apr 1, 2010 | 03:54 PM
alnielsen's Avatar
I never called you stupid. I asked questions. I'm wondering what will happen on a 90+ degree day and the asphalt temps are 120.
Old Apr 1, 2010 | 04:51 PM
Brettus's Avatar
Boosted Kiwi
interesting idea
Old Apr 1, 2010 | 05:02 PM
Pics? What exactly did you do?
Old Apr 1, 2010 | 07:07 PM
Is this an April Fools Joke?
Old Apr 1, 2010 | 08:26 PM
olddragger's Avatar
BINGO!!!!!!!!
My man Dan got it!
Sorry guys --if this rubbed some one the wrong way i apolitical---just couldnt resist.
Actually in cold climates this idea may have some merit
and for drag racers it is used all the time
Happy April fools joke gang
rotor on
olddragger
Old Apr 1, 2010 | 08:31 PM
Ahh ****, I can't believe I fell for that.
Damn uuuuuuuu !!!!
Old Apr 1, 2010 | 08:32 PM
Easy_E1's Avatar
Smooth.
Old Apr 1, 2010 | 09:08 PM
Brettus's Avatar
Boosted Kiwi
you would have been better to promote this :
http://kalecoauto.com/index.php?main...products_id=35
Old Apr 1, 2010 | 09:15 PM
Flashwing's Avatar
3-wheeler
The best comedy is rooted in fact.
Old Apr 1, 2010 | 09:34 PM
heyarnold69's Avatar
Rotary wanabee
i hate you forever hahahhahahahahaha
Old Apr 1, 2010 | 10:03 PM
I am so glad April Fool's is almost over
Old Apr 2, 2010 | 08:39 AM
olddragger's Avatar
hahaha--yall are getting to be more like family--so I HAD to do this.
Old Apr 2, 2010 | 09:40 AM
HiFlite999's Avatar
And many facts come out of what first seems comical!
Old Apr 2, 2010 | 11:40 AM
olddragger's Avatar
---hmmmmm i wonder?
Old Apr 2, 2010 | 02:10 PM
HiFlite999's Avatar
Originally Posted by olddragger
---hmmmmm i wonder?
I should have known better than to add fat to this fire!
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
Tsurugi
Sep 7, 2015 08:27 PM
