standalone
Old Mar 27, 2010 | 10:02 AM
9000k's Avatar
standalone
Has anyone got suggestions on standalone systems? Im working on putting in a fd trans and keeping the renesis and taking off the ac, ps, omp, and boosting it. Please help. Thanks
Old Mar 27, 2010 | 10:06 AM
Budget?
Motec if you have the cash.....
Why would you remove the power steering?
Old Mar 27, 2010 | 11:26 AM
9000k's Avatar
My bad not ps but i have about 1500bucks to spend so no motec lol.
Old Mar 27, 2010 | 11:28 AM
tubingchamp's Avatar
What mawd bug?
I don't think we have a "budget standalone" around $1500..
Why would you put an FD trans on the Renesis?
What's wrong with a Cobb?
Ahh, confusing.
Old Mar 27, 2010 | 11:43 AM
9000k's Avatar
Because my blew up lol so I had a fd trans and thought I would try using it
Old Mar 27, 2010 | 12:04 PM
$ 594 for MM Cobb AP would likely be your best bet... Comes with tuning
Standalones under $1500 are not going to happen
An Int X could be picked up for sub $400 also
Nothing cheap runs the throttle and dash standalone without the stock ECU anyway...
Old Mar 27, 2010 | 06:47 PM
9000k's Avatar
So would a cobb with mazdamaniac work?
Old Mar 29, 2010 | 03:32 PM
arghx7's Avatar
Interceptor X is probably the best route, but I would only use it if you have a large turbo upgrade where the MAF sensor becomes impractical to retain
Old Mar 29, 2010 | 08:10 PM
Depending on the power output you want...you may be OK with the MAF...or not
If you want to go MAP..the Intx ( Microtech LT10) would be a good alternative..it reads the stock trigger wheel...and you can buy a used one on here cheap...way less than you could buy the Microtech for
Old Mar 29, 2010 | 09:02 PM
mscamp02's Avatar
Blue Bullet?
I think I remember people talking about putting in the fd 5 speed trans but it took some work,
Old Mar 29, 2010 | 09:18 PM
sauceyI986's Avatar
while since were on a subject for ems, i was planing to run a Garrett GT35R on my engine and wanted to see which setup would be better Cobb or intercepter x
F51
Aug 2, 2021 04:07 AM
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
iTs Ghastly
Aug 28, 2015 02:40 AM
Turblown
Vendor Classifieds
214
Feb 27, 2013 02:25 PM
brillo
Dec 30, 2006 05:12 AM
