Zex kit wth greddy turbo
Old Mar 21, 2010 | 06:11 PM
freaklinkmusic's Avatar
so im getting a zex kit for my bday(old lady said she ordered it 4 me... wondering how it will fare with my upcoming turbo??
do it? or dont do it?
Old Mar 21, 2010 | 06:17 PM
mscamp02's Avatar
Blue Bullet?
Im not sure anyone on heres is even running both simultaneously. Could be wrong though
Old Mar 21, 2010 | 06:18 PM
don't do it.
as CRH mentioned: it's not needed and without a very good tune, I could see this ending very badly.
Old Mar 21, 2010 | 06:19 PM
well im scared to sell it since she bought it for my bday. Maybe I can make it look as if its hooked up. lol. if no one credible such as you, MM, or other rotary tech guys dont think its a good idea i wont hook it up at all
Old Mar 21, 2010 | 06:20 PM
funny thing is, she doesnt know that im getting turbo. She just happen to snoop behind me and saw I was looking at a zex kit.(wasnt planning to buy)
Old Mar 21, 2010 | 06:22 PM
Brettus's Avatar
Boosted Kiwi
I say you have an awesome GF - definately a keeper .
And yeah , don't hook it up
Old Mar 21, 2010 | 06:38 PM
If you are seriously close to getting/installing a turbo kit, then do that. If you are still a little while away from getting it, install the nitrous and enjoy it until the turbo kit arrives.
about 2 months away from the turbo. zex will be here on wednesday. jus a quik question, how long does a "full bottle" typically last?
Old Mar 21, 2010 | 06:59 PM
Mr.We$t's Avatar
Rx-8 the protege
Yea +1 on ^ I bought a kit from him ( which works excellent by the way thanx again Charles) and I got trigger happy and the bottle was empty in in 5dayz I was really tryna get adjusted to it so that's why I was trigger happy!
I ordered a second bottle and a bottle opener for the next stage of my project!
Side note: cahrles Ima send u some pix of my purge setup I just want ur input on some things thanx again!
Old Mar 21, 2010 | 07:25 PM
ZumnRx8's Avatar
RX8 & RX7 owner
^dos botellas? ay ya yai
Old Mar 22, 2010 | 12:10 PM
Mr.We$t's Avatar
Rx-8 the protege
Yea I'm trying to make a setup so that when the first bottle is empty the second bottle will open automatically!
Old Mar 22, 2010 | 01:40 PM
Mr.We$t's Avatar
Rx-8 the protege
You would be better off parallelling the bottles through a manifold and having your remote opener open a common valve between the two tanks.
I was gonna fabricate a relay that will activate the opener when the main bottle is empty is that what u mean?
Old Mar 22, 2010 | 05:26 PM
Mr.We$t's Avatar
Rx-8 the protege
Before I opine, would you care to share your logic as to why this is an attractive or desireable option?
Well the main reason is cuz where I live I have to drive an hour to fill up the tank and it doesn't last long enough for my taste!
Also I wanted to try and come up with some new ideas for a local buisness I started with some friends
Old Mar 22, 2010 | 05:33 PM
paulmasoner's Avatar
Asshole for hire
edit: ^^ got in before me, and was saying the same thing i was, but in a much more understandable and educated way
Old Mar 22, 2010 | 05:39 PM
Mr.We$t's Avatar
Rx-8 the protege
Maybe I misunderstood but that's what I mean I want 2 bottles in one setup but I don't want both bottles open at the same time. What I mean is when the first empties the second will open and be the supply
Old Mar 22, 2010 | 05:49 PM
Mr.We$t's Avatar
Rx-8 the protege
Nobody is misunderstanding anyone here. Something you may not realize is that nitrous systems operate best when the nitrous pressure is most stable. Your idea does not provide this as well as it could be achieved.
Ok i understand somewhat but I figured it was like adding a second stage to the system! Guess it's back to the drawing board
but in regards to what u were saying about the parallel bottles can u explain that a little more
Old Mar 22, 2010 | 06:03 PM
Mr.We$t's Avatar
Rx-8 the protege
Let me finish explaining the issue about pressure stability; when your nitrous tank is full it will have 900-950 PSI (depending on your ambient temperature). As you use it, the pressure drops. As it does this, your nitrous system will slowly (and slightly) begin to run a little richer. Once your tank reaches about 600 PSI it will be rendered useless and only have about 20% capacity. However long this takes depends on how you use your system.
With the plan you have this is what would happen with each tank.
If you were to parallel the tanks together, your pressure would remain in the optimal range for 2x as long until both tanks need to be refilled.
Now I understand completely and it makes sense y u would say it wouldn't work! So in parallel would it be that one bottle would keep the pressure of the other bottle in the optimal range?
Sorry for the rookie questions but I'm still learning
Old Mar 22, 2010 | 10:55 PM
jeffRX's Avatar
Black on black on black..
Oo! Oo! I have a question Charles! lol I'm not a physics major so I wouldn't know the answer to this but wouldn't having both tanks open also put 2x as much pressure into the lines? I would like to have two tanks but was worried by having 2 tanks open that the solenoids or even the threaded lines would be under emense pressure...
Old Mar 23, 2010 | 03:00 PM
easy have you looked into this?? didnt know if it was a legit manifold or not. never seen anyone use it.
http://www.essentialgears.com/tho/tr...D-3942733.html
Old Mar 23, 2010 | 03:05 PM
gregs's Avatar
Pull My Finger
i just checked the greddy web site and that is not listed..kinda weird
Old Mar 23, 2010 | 05:14 PM
gregs's Avatar
Pull My Finger
The part number listed is for the RX-8 oil pan.
I am not "easy".
maybe "easy" to deal with??
Old Mar 23, 2010 | 08:13 PM
I am not "easy".
yeah i know. i was referring to the user EASY, it was some dry humor being that hes blown up a couple manifolds
Old Mar 24, 2010 | 03:39 PM
jeffRX's Avatar
Thumbs up
Nope. Same pressure, 2x the volume available.
very smexy. can't wait to install that second tank for your highly antisipated upcoming 150 shot upgrade lol
Old Mar 25, 2010 | 12:45 PM
jeffRX's Avatar
ohhh its gonna be sick! lol I can't wait to start beatin up on some of these faster cars i.e. camaros, stangs, vettes, moded evos, sti's, skittles, genesis..'s? youtube my name ( mehmehxxx ), if you're interested, I have a couple races on there.
Last edited by jeffRX; Mar 25, 2010 at 12:46 PM. Reason: forgot the american rivals
Old Mar 25, 2010 | 01:15 PM
Mr.We$t's Avatar
Rx-8 the protege
Hay Jeff how long u been running nos on ur ride?
And what upgrade are u guys talking about I'm intereasted
Old Mar 26, 2010 | 08:42 PM
jeffRX's Avatar
about a year now i guess. the upgrade is being worked on by BHR but is a long way off unfortunately... right now the safest shot is the 55 offered by zex. if you have any questions everything is on the forum and if u can't find it then ask CHR. he knows all when it comes to nitrous. good luck
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Sep 27, 2015 07:49 AM
Digitz0070
Sep 25, 2015 10:58 PM
