Turbo RX8
Old Feb 25, 2010 | 05:08 PM
69vdub's Avatar
Turbo RX8
Built a couple turbo cars before. New to these Rotary engines, and looking to buy a RX8, I was thinking of Turbo a RX8, only plaining on running 7 - 8 psi, just wondering if that would be to much boost for a stock Rotary and too hard on the seals, Also how will the injectors and fuel pump keep up. Newbee questions but wouldn't mind some help
Old Feb 25, 2010 | 05:16 PM
Brettus's Avatar
Boosted Kiwi
that's fine as long as you don't run lean for any reason - the Renesis seals will take a little abuse but not much in comparison to a piston engine .
Many turbo owners are now moving to stronger seals .
Old Feb 25, 2010 | 06:05 PM
69vdub's Avatar
Is it nesasary to put a bigger rad in it? also for the tunning and computer can i just use the Cobb Accessport, Should I do anything with the mass air and intake temp sensor. Do you guys use the GM 4 bar map sensor
Old Feb 25, 2010 | 06:17 PM
Brettus's Avatar
Boosted Kiwi
you need to read the stickies at the top of this forum
Old Mar 13, 2010 | 05:40 PM
04RX8man's Avatar
Rotary Powered Countryboy
this is a maf based car..AP to tune....in this car a bigger RAD is a good idea turbo or not LOL....
3mm apex seals FTW!!!
Mxttz0r
Jul 5, 2019 03:19 AM
UHATEIT
Mar 31, 2019 05:31 PM
jay_tibo
22
Sep 13, 2016 08:10 PM
PotatoCannon
Sep 6, 2015 11:48 AM
shambo
Jul 18, 2015 02:07 PM
