View Full Version : Ignition system and nitrous
syntax17 02-03-2010, 11:37 AM hi,
i like to buy a zex nitrous system from blackhaloracing.
how must i modify my ignition system to run with nitrous?
sorry for my english;)
Huey52 02-03-2010, 11:58 AM You really don't have to mod the ignition for nitrous (it's basically just denser air providing more O2, to which the ECU will adjust), but since you're getting it from BHR, you'd be well served also getting their upgraded ignition system (recommended even if stock).
Phish806 02-03-2010, 11:59 AM Technically you do not NEED to modify your ignition. However, Its definately a good idea to make sure that your coils are in excellent condition. Upgraded coils would be a Very Very good idea. A misfire with any power adder can be a bad thing and lead to many differnet issues.
To sum it up. If you want to save money and take the risk of misfires while spraying, stick with the stock coils. If you would rather play it safe, upgrade the coils to an aftermarket set.
syntax17 02-03-2010, 12:22 PM thanks for the fast answer, where can i get this coils?
and can you give me any other tips to modify the engine for nos?
Huey52 02-03-2010, 12:28 PM Again, get the BHR ignition system which includes better GMC Yukon coils.
Of course get the BHR custom throttle body spacer and nitrous nozzle when you get the Zex kit. http://blackhaloracing.com/products-page/power-adders/nitrous/bhr-throttle-body-spacer6/
You may also want the bottle warmer.
I'm sure the BHR folks will chime in with other suggestions.
bse50 02-03-2010, 12:28 PM Since you want to buy your Zex kit from BHR you may want to know that they are the manufacturers of the ignition kit Huey mentioned as well :)
syntax17 02-03-2010, 12:39 PM in a support mail have charles say i dont need the body spacer, i can drill a hole in the rubber intake but its easyer with the body spacer. what think you guys?
what is the effect of the bottle warmer?
Huey52 02-03-2010, 12:46 PM ^ Go with the BHR spacer and nozzle. Don't get cheap right at the most critical juncture!
Every component is well described, to include its purpose, on the BHR website - one link to a customer. ;)
Jedi54 02-03-2010, 12:50 PM I would recommend the Throttle Body spacer as opposed to drilling the rubber intake hose since it's more of a plug & play and you could remove the nitrous at a later date while leaving no evidence that it was there before. (hint hint) :suspect:
bottle warmer helps maintain consistane performance, it's a great idea for those going Nitro
syntax17 02-03-2010, 12:53 PM the ignition kit must be build i have seen.
is it ok when i buy for the first time the nos kit, a body spacer and the nitrous nozzle?
you say i dont need so much a ignition kit and i have not sooo much money ;)
so i an buy the ignition in the next month.
Huey52 02-03-2010, 01:49 PM Yes, the BHR ignition system has been pictured and thoroughly discussed here in this forum. You can wait on it, although it would be nice to do all the under-hood work at one time. Why not save for awhile longer.
Again, I would recommend you do get the BHR spacer and nozzle when you buy the Zex kit from them.
syntax17 02-03-2010, 02:01 PM allright i get the two tihngs to the kit... tahnks at all for the great answers it was very helpful;)
