Rear end is slipping??????????????
Old Jan 10, 2010 | 10:37 AM
bmarrs's Avatar
Hey guys, I have noticed that when I take off hard in 1st and 2nd gear that it feels like the rear tires are spinning but I think that it is actually the LSD slipping... I live in AR and the temp has went from 30 to 5 in the last couple of weeks so not sure if its that temp or if I may have rear end troubles... Imy '04 has 108000 on it so anyonr had this problem or any suggestions would be greatly appreciated..
Thanks, Billy
Old Jan 10, 2010 | 10:50 AM
Easy_E1's Avatar
The rear end is not going to slip internally. Do you have an AT or a MT trans?
Old Jan 10, 2010 | 11:24 AM
Brettus's Avatar
Boosted Kiwi
It's your tyres slipping ....
Old Jan 10, 2010 | 12:00 PM
CRO8TIA's Avatar
If your ride is an auto,have you done a fluid + Filter change recently,maybe due for a service, if it's a stick,is it the original clutch,do you smell anything like a putrid burning smell when this happens.If it is a clutch on its way out,a quick way to check if its slipping is to apply the "E" brake,select 5th gear and try to take off,not like 9000revs and dump it,just like you would normally,if it doesnt stall the motor,it's probably the clutch.
PS. nice front end Brettus.
Old Jan 10, 2010 | 01:12 PM
Old Rotor's Avatar
Thanks, Billy
When tires and the road are cold you loose grip.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Paul_Y
Sep 21, 2015 02:23 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
