Front driverside ABS harness needs replacement
Old Oct 27, 2009 | 09:51 PM
rx2kill's Avatar
wanting another rotary
FL Front driverside ABS harness needs replacement
So I changed my suspesion out, in the process I apartantley did some damage, made the ABS light and stability control light go off, I tried all the little reset tricks, none of which worked, whilst my car was at mazda(yes I just used that word haha), they said it was the front abs harness, its a two foot section of wires I have seen, does anyone know where to buy this part other than from mazda??? I have tried mazmart, they never wrote me back, I called them they said theyd write me back. Its been a week, no reply. Also it seems like a easy fix given I get the part, any tricks to replacin the harness??? Thank you. ~RX
Old Oct 27, 2009 | 10:24 PM
Jon316G's Avatar
Grasshopper
If its just the wire harness that is damaged, just cut the wires next to the harness (removing the OEM harness) and splice/crimp bullet terminals.
This way you won't have to worry about crimping the same style pins into a new OEM harness.
Or you can purchase the whole sensor assembly which should include the sensor, wire, and harness.
OnlineMazdaParts.com has them for $62.91
Old Oct 28, 2009 | 08:56 AM
rx2kill's Avatar
wow thanx man, I really suck at electrical stuff so Id prolly opt to just get the whole part, I know crimping is easy but that over time can come loose, and if there was a special olympics for soldering, Id prolly place just above last, so thank you.
Old Oct 28, 2009 | 08:59 AM
rx2kill's Avatar
Jon, could you send me a link to where the harness is? I went to the site but dont know what categorys to follow
Old Oct 28, 2009 | 01:36 PM
Jon316G's Avatar
Grasshopper
Look at the left task pane on the attached pic below and follow the "path" to get to that sensor.
Old Oct 29, 2009 | 05:05 AM
rx2kill's Avatar
The abs harness is considered the speed sensor?
Old Oct 29, 2009 | 05:12 AM
Jon316G's Avatar
Grasshopper
No.
The speed sensor is on one end of the wire and the harness is on the other.
When you purchase it, you get the whole setup so you don't have to worry about crimping new pins into a harness.
Old Oct 30, 2009 | 04:57 AM
rx2kill's Avatar
oh alright, think I remember how that would be than, speed sensor by the rotor than the bart under the bumper is the harness. U have any pix
Old Oct 30, 2009 | 05:11 AM
Jon316G's Avatar
Grasshopper
Sorry... no helpful pics.
Only this pic from the service manual:
Old Nov 29, 2009 | 02:20 PM
rx2kill's Avatar
I ordered the harness and today I changed it out, My ABS light and that stability light are still on WTF!!!!!!!!!!
Billy Marcial
Mar 1, 2018 06:50 AM
Solidtrance
22
Sep 4, 2015 12:47 PM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
MolecularConcept
Aug 1, 2015 03:15 PM
