tmak26b
08-16-2009, 08:10 PM
I am just curious as to what happens to the AC system after the reset? I did the AC reset as instructed on rx8blog.com. I do have to admit it actually works as my AC cycles less and it is noticeably colder.
View Full Version : Resetting the AC, what does it do? tmak26b 08-16-2009, 08:10 PM I am just curious as to what happens to the AC system after the reset? I did the AC reset as instructed on rx8blog.com. I do have to admit it actually works as my AC cycles less and it is noticeably colder. Low Fly'n 8 08-16-2009, 08:24 PM I believe it just defaults to "reirc" anytime you turn the air on. AC RESET: 1. Make sure the car is off AND the HVAC fan is off AND the A/C on/off button is off. 2. Press and hold the front defroster (on the left) AND air source (recirc/fresh air) buttons 3. Continue pressing the buttons in step 2 and turn the key to ACC for 3 seconds 4. Continue pressing the buttons in step 2 and further turn the key to ON (NOT START) for 3 sec. 5. Verify the programming update by observing the REAR defroster LED blink 3 times. 6. Release the two buttons from step 2 and start the car. swoope 08-17-2009, 01:31 AM you answered your own question. it keeps the compressor from cycling as often, and when you turn it to full cold it switches to recirc... and yes, it helps a lot. beers :beer: Nubo 08-17-2009, 12:28 PM Changes the "duty cycle" from on-off-on-off-on-off-on-off to on............off...on............off...on........ ..... And puts AC in recirc mode whenever ambient temp is over 68F, temp set to min. and vents are in "face mode. tmak26b 08-17-2009, 03:22 PM What makes the system cycle less before the set? swoope 08-20-2009, 01:23 AM programing of ac amplifier.. beers :beer: 9krpmrx8 08-20-2009, 01:28 AM Cool, have to try this. |
