Fuse for priming turbo
What fuse do I need to pull so the engine will crank over and not start. The Greddy instructions say pull the PCM fuse but I didnt see anything labeled PCM. I tried pulling the fuel fuse, and it started, I pulled the ECS fuse and it didnt even turn over. Even though I have started the car and the turbo has oil, its leaking, so I want to just turn it over instead of having to turn the car on then turn it off. Thanks!
Adam
Adam
adam it sounds like you got that charge pipe hooked up i assume? if you want the engine to just crank, ill look at the diagram and hopefully chime in sooner than anyone else may of assistance..
but it will still turn over right??
^the top nut on the downpipe is easily accessed if you lower the engine down all the way
this of course means you need to have the motor mount out
I have installed my kit about 3 times now...you will learn the tricks eventually, lol.
Ya, I think Im gonna have to drop engine anyway to get a good grip on the feed line and was already thinking it would be easy to get the nut with the engine lowered. I just want this stupid car to be done!
Ya it was, but I think thats what is leaking. Im going to get a telescoping mirror and start the car and see where is leaking from. I took Bryans advice and used liquid teflon, and Im wondering if thats my problem.
yes disconnect he ecc. shaft sensor it will crank but not start....good to prime it but like chickenwafer said that once it's primed look to see if it leak from that pressure....if it does try to fix before a start...if no leaks visible after prime...start it up and do a THOROUGH check of all lines fittings etc etc.
It will more likely be the drain bolts - remember how you can't tighten that back one up?
It dribbles and drips onto the manifold below. Use your mirror to find the black spot right below the inboard bolt of the drain fitting......
Pull the fitting off and wet the gasket with Hylomar or similar gasket goo, then tighten the inboard one as far as possible before you install the outside bolt.
S
S
To remove it, you would lift it out, but to give yourself a little more room to work on a turbo, you'd remove one or both engine mounts and jack it down. Gives 3 or 4 inches more room.
Lower the jack carefully - easy to squish the wastegate actuator into scrap.......
S
S
S
S
I used phillips head bolts instead of the 10mm bolts...worked awesome
S
S
Evan Gray
Sep 26, 2015 12:30 PM
