Rote8
07-23-2009, 05:15 PM
When you turn on the key, then press the brake twenty times, in very fast presses, what gets reset when the oil gauge goes to the middle and back down?
I have been told this resets the fuel injection timing/crank position sensor, is this true?
Why would I need to do this for better idle?
Why does my long term trims raise by 3 when I do this?
:confused:
Jedi54
07-23-2009, 05:26 PM
I'm pretty sure the fuel trims get reset so that's why LTFT is off by 3.
here's more details on clearing it: http://www.rx8club.com/showpost.php?p=349432&postcount=3
Rote8
07-23-2009, 06:26 PM
No, I have tested the "Press the Odometer button" reset, it does not reset the Long Term Trims, at least from the Data logs showing LTTs.
Jon316G
07-23-2009, 06:42 PM
The procedure that MM mentioned with holding the odometer is incorrect.
This will not reset anything... that menu is used to test inputs/outputs.
I talk about that in this thread:
http://www.rx8club.com/showthread.php?t=155947
I suggest reading this for the accurate way to clear the PCM and to understand what you're clearing:
http://www.rx8club.com/showthread.php?t=169443
Jedi54
07-23-2009, 06:46 PM
damn it, I gotta stop quoting such old posts.
thanks for the correction Jon.
04RX8man
07-23-2009, 07:36 PM
^wow jedi got corrected that's a first! haha
I was told pulling the room fuse will reset both the LTFT and the STFT...and that it will take a few drive cycles for the PCM to relearn the trim settings.
rodjonathan
07-23-2009, 08:34 PM
are any of these necessary or does the ecu learn these over time anyway
nycgps
07-23-2009, 10:15 PM
ECU will re-learn over time.
swoope
07-24-2009, 02:13 AM
all the rules changed with the r flash..
beers :beer:
Charles R. Hill
07-24-2009, 09:20 AM
beers :beer:
How so?
swoope
07-28-2009, 12:16 AM
How so?
fuel trims dont clear with the brake tap, they did before the r flash...
battery pull or fuse pull.
beers :beer:
Razz1
07-28-2009, 11:15 AM
Man... I love dat beer cup holder.
Wat da Man said room fuse.. :beer: :beer05:
