Buying Used turbo
Old Jul 7, 2009 | 02:28 PM
lokoebird's Avatar
DON'T HATE THE 8
From: Im' from Guam. Stationed in Colorado. Deployed to Iraq.
Buying Used turbo
What do I look for when buying a Used turbo?
Old Jul 7, 2009 | 03:13 PM
Nothing. Don't buy a used turbo. But if you must buy used then check for shaft play.
Old Jul 7, 2009 | 03:14 PM
which used turbo?
(please OH gawd don't let him say Greddy...)
Old Jul 7, 2009 | 06:36 PM
05rex8's Avatar
sold the 8... :(
the search function
Old Jul 7, 2009 | 06:37 PM
Spinning Sushi's Avatar
I <3 Sushi
[embed]B9q2jNjOPdk[/embed]
Old Jul 7, 2009 | 06:38 PM
05rex8's Avatar
sold the 8... :(
Originally Posted by Jedi54
which used turbo?
greddy kicks *** once it's rebuilt and upgraded properly
Old Jul 7, 2009 | 06:50 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I dont think you can determine shaft play just by feeling it. If it moves so much that you can feel it, it is REALLY gone. (Mine did when I pulled it.) But, it could be out of spec and you might not be able to tell with your fingers.
But to answer the OP, you should look for a turbo that fits your application, in flow characteristics, flange fittings, lubrication, cooling and clearance. I think that covers all the bases?
Old Jul 7, 2009 | 06:54 PM
Brettus's Avatar
Boosted Kiwi
Buying a used greddy turbo is a great option - the worse shape it is in/cheaper you can get it . the better . Then get it upgraded and rebuilt by BNR and you have got something way better and cheaper than if you had bought a new greddy ...... IMO
Old Jul 7, 2009 | 08:34 PM
blackenedwings's Avatar
Life begins @ 30 psi
Listen to Brettus, he knows what he is talking about here! I would buy a junked GReddy turbo and send that off to Bryan@BNR asap. Inexpensive and great option by all reports.
Old Jul 7, 2009 | 08:50 PM
04RX8man's Avatar
Rotary Powered Countryboy
I agree with finding the searchfunction!
Old Jul 8, 2009 | 12:06 AM
MazdaManiac's Avatar
AZ
Old Jul 8, 2009 | 06:16 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
That's not bearing play, that is a self-centering axel. That's a feature!
Old Jul 8, 2009 | 12:18 PM
Brettus's Avatar
Boosted Kiwi
Interestingly , the 2nd hand turbo i got had about that amount of play so I got it rebuilt before fitting it . When I tried it again after the rebuild there was bugger all difference .
Since then it has done about 12000 miles with no issues .
Old Jul 8, 2009 | 01:00 PM
yeah I have had rebuilds that have lasted just as long as new Greddy Turbos.
Old Jul 8, 2009 | 01:28 PM
Im_DANomite's Avatar
I love GOOOLD
buy my kit, that is all.
Old Jul 8, 2009 | 07:46 PM
04RX8man's Avatar
^what kit ru selling?
Old Jul 8, 2009 | 11:35 PM
Bryan@BNR's Avatar
Turbocharger Guru
A mitsubishi TD05/6 has around .035" up and down movement and .015" in and out movement. With oil in the turbo, you shouldn't feel any in and out (thrust) movement. Up and down you should feel a little bit, but the rotating assembly shouldn't touch the end housings as you are pushing and pulling on it by hand.
A typical garrett has .030" which is a little tighter than the Mitsubishi or Toyota turbos which are a little less tight.
The thing about the greddy units is the CHRA being non water cooled. This causes rear journal bearing coaking which can't be seen unless you take the turbocharger apart. When it coaks up so much, the car will start smoking after 30-45 seconds after you crank the car.
Old Jul 9, 2009 | 12:49 AM
i just cried a little..
thanks for that..
Old Jul 9, 2009 | 12:50 AM
uh,
did you mention search?
Old Jul 9, 2009 | 12:53 AM
Originally Posted by MazdaManiac
oh baby,
yea thats the spot.. yes, yess, yesssss. o god. i love you..
the turbo is spent.
Old Jul 9, 2009 | 12:56 AM
I <3 Sushi
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Octomus
Sep 3, 2015 11:40 AM
