View Full Version : td04 turbo
VS8
07-07-2009, 12:57 AM
is the td04 turbo from the subaru wrx to small to put in my car...i have one just wanting to be used
dannobre
07-07-2009, 01:17 AM
Its smaller than the Greddy Kit snail......so what would you think ;)
05rex8
07-07-2009, 01:22 AM
roflsauce
VS8
07-07-2009, 02:08 AM
well it just seems like waste of turbo
Mawnee
07-07-2009, 02:51 AM
Buy a WRX to bolt it to ? :D:
bse50
07-07-2009, 03:38 AM
If you're not able to read a flowchart for a turbo you can't build a properly balanced turbo kit for your car from scratch.
There are some charts posted here that might help your research and build though ;)
Building a kit is not just copy\pasting some objects on some pipes!
chickenwafer
07-07-2009, 10:37 AM
It's a bad idea
ChrisRX8PR
07-07-2009, 11:07 AM
Get another one or two and put them all on...maybe then will you have enough flow for about 340whp...
Chris
9krpmrx8
07-07-2009, 11:10 AM
Way too small, get a T88, that should suffice.
VS8
07-07-2009, 02:19 PM
how bout the vf39 from the sti
bse50
07-07-2009, 02:26 PM
IHI VF39
Aspect ratio 18
Turbine Impeller Dia ID 48mm/ OD 53mm, 11 blades
Compressor Impeller Dia 46.48mm/60mm, 6+6 blades
Equipped with compressor blade sealing
Wastegate port 25mm dia
WG Port open 77.7 kPa @ 2mm, 89.9 @ 4mm
Now it's up to you.
9krpmrx8
07-07-2009, 02:30 PM
There are better options, the VF39 does not have a ball bearing center section. BTW, it's an IHI turbo. Plus isn't it a dual scroll turbo? I could be wrong though.
VS8
07-07-2009, 02:34 PM
its a single scroll...only reason i ask is because i have 3 friends who have turbos just laying around
9krpmrx8
07-07-2009, 02:37 PM
I know one of the STI's had a dual scroll, either way its too small I think for the rotary. Look up the flow charts for the VF39.
