Electric motor noise under the hood.
Old Jul 7, 2009 | 12:00 AM
santarosarx8's Avatar
There is a loud electric motor noise coming from under the hood on startup, and lasting for a few minutes. The electric motor is on top and to the left of the engine between the battery and the washer bottle. The connector is right on top, so I pulled it. The noise went away, confirming the source of noise.
What does this motor do, and why is it so noisy?
Old Jul 7, 2009 | 12:08 AM
Air Pump....emissions device...not really important
It's noisy cause the pump is screwed
Old Jul 7, 2009 | 12:20 AM
Brettus's Avatar
Boosted Kiwi
It should sound a bit like a vacuum cleaner motor - cuz that is what it is
If it is really noisy then dannobre is correct - it is munted .
On a bright note - lots of us have removed it so if you ask , someone will most likely sell you one pretty cheaply .
Old Jul 7, 2009 | 03:48 PM
04RX8man's Avatar
Rotary Powered Countryboy
or u could always just remove yours
Old Jul 7, 2009 | 03:53 PM
Are these people serious about this ?
I mean, dude, get to know your car. Mr. Epic failed.
Old Jul 7, 2009 | 03:54 PM
Z0oMzo0m's Avatar
removing it, does it or would it make any difference? i guess its taking voltage and little power, but enough to do anything?
Old Jul 7, 2009 | 04:26 PM
Brettus's Avatar
Boosted Kiwi
removing it will earn you a CEL . So unless you can live with that or have the AP it is not such a good idea ....
Old Jul 7, 2009 | 04:33 PM
04RX8man's Avatar
^NO black electrical tape ALSO takes care of the CEL hahaha
Old Jul 7, 2009 | 05:01 PM
It should only make noise on cold start up and then go away.
Old Jul 7, 2009 | 07:23 PM
04RX8man's Avatar
^yeah it's something like 2 minutes after start up(cold) should it be on.....
Old Jul 8, 2009 | 01:09 AM
I am much relieved. But what the heck does it do? I mean does it actually accomplish anything?
Old Jul 8, 2009 | 01:16 AM
Injects air into the exhaust manifold at cold startup to rapidly heat up the CAT so it works more efficiently
Old Jul 8, 2009 | 12:34 PM
04RX8man's Avatar
^and help reduce emissions on start up...
Old Jul 8, 2009 | 08:58 PM
Uber failed.
Mane
Nov 20, 2015 12:16 PM
Luke.s
Sep 30, 2015 05:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
