blaffee
07-04-2009, 07:51 AM
Has anyone experienced oil in the air filter? Oil is also in the hose that leads from the air filter to the engine. During an oil change they said it might be oil blowing through the PCV valve.
View Full Version : Oil in air filter blaffee 07-04-2009, 07:51 AM Has anyone experienced oil in the air filter? Oil is also in the hose that leads from the air filter to the engine. During an oil change they said it might be oil blowing through the PCV valve. expo1 07-04-2009, 08:12 AM http://www.rx8club.com/showthread.php?t=176356 http://www.rx8club.com/showthread.php?t=171117 http://www.rx8club.com/showthread.php?t=157858 http://www.rx8club.com/showthread.php?t=121168 http://www.rx8club.com/showthread.php?t=119297 http://www.rx8club.com/showthread.php?t=82803 http://www.rx8club.com/showthread.php?t=86962 StealthTL 07-04-2009, 08:21 AM You don't have a PCV valve..... S blaffee 07-04-2009, 01:14 PM Thanks, Expo1 the links you provide expained the problem and what I need to do. Vyndictive 07-09-2009, 07:41 AM Blaffee: Same thing happen to me, but became a serious problem because oil got into the lower intake manifold causing it to stay closed and thus, causing the car to stall when it should idle. full story at 11 http://www.rx8club.com/showthread.php?t=162200&highlight=vyndictive |
