putting seafoam in the oil
Old May 15, 2009 | 03:33 PM
Mr.&Mrs.Magic's Avatar
I'm about to seafoam for the third time and in my boredom i decided to read the can. It said I could add it to the oil and clean out some gunk that way anyone think this is a bad idea with the rotary. I'll only be leaving it in for a week as i'll be doing a full oil change and switching to royal purple with the sohn opm adapter injecting clean oil. Just figured i'll try and get as much eww out as possible. I'll also still be injecing the seafoam thru vacuum tonight.
Old May 15, 2009 | 03:35 PM
04RX8man's Avatar
Rotary Powered Countryboy
I wouldn't see how it would hurt anything...but i'd prob just personally use it through vacuum...
Old May 15, 2009 | 03:44 PM
My concern is that the seafoam will keep my engine from getting proper lubrication if it's in the oil itself. Just a thought ya know?
Old May 15, 2009 | 03:46 PM
Shouldn't use any oil flush type additives to the oil...you can not get them all out by doing an oil change...even doing a couple back to back will still leave a significant amount of the additive in the residual oil
Old May 15, 2009 | 04:02 PM
Brettus's Avatar
Boosted Kiwi
/\ good point Dannobre . You don't want that stuff in there for an extended period ....
Old May 16, 2009 | 03:18 PM
shadycrew31's Avatar
WENTGERMAN
putting in the oil is more a piston thing.. just do regular changes and you wont need a cleaner.
Old May 17, 2009 | 08:28 AM
Care to explain this statement?
Old May 17, 2009 | 11:49 AM
04RX8man's Avatar
^i think he is talking about that since our oil is used inside the combustion chamber that it's not a good idea since it may not give proper lube to teh rotor housing and side/apex seals..
Old May 17, 2009 | 11:08 PM
AJ's Shinka's Avatar
Enthusiast
I have already put it in my oil!
Old May 17, 2009 | 11:25 PM
if the oil sucks, it doesnt matter what u put into it, it will still suck.
all motor oil has certain amount of cleaning agents in it already. there is no point of putting seafoam or anything like it in there.
Just use quality and heavier than 5w20 oil, change it regularly, use premix in your gas. you are mostly ok.
Old May 17, 2009 | 11:28 PM
Just remind you all kinds of motor oil and gasoline has cleaning agents in them.
Im not saying its a good idea to put seafoam into your motor oil tho, IMO thats just a waste of money and it will NOT improve anything.
Old May 18, 2009 | 12:10 AM
Flashwing's Avatar
3-wheeler
I would not suggest putting seafoam into your motor oil. As you stated, the properties of seafoam cause oil to be stripped from surfaces they are protecting which will cause damage to the motor.
This is why Mazda increases OMP input when using seafoam during their decarb process. They want to ensure there's still lubrication. I used a max oil accessPORT flash where I cranked the OMP to 60 when I decarbed my motor.
As nycgps stated, both gasoline and oil have cleaning agents in them.
Old May 18, 2009 | 11:52 AM
WENTGERMAN
I think they did it for me. that's what I was getting at, I just didn't want to put allot of effort into it .
UHATEIT
Mar 31, 2019 05:31 PM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
rotorsnsaabs
Aug 26, 2015 08:21 PM
reni04
Aug 21, 2015 01:33 PM
RoddyMac
Aug 5, 2015 04:21 PM
