reflash or new computer??
Old May 5, 2009 | 10:56 PM
jstieber's Avatar
I am hoping someone could respond with an approx cost of a reflash and also the cost of a new computer for the car. oem please. and labor costs approx? my car has been on this forum multiple times for discussion and so far any of the "solutions" have fixed anything. the last shop i had it to (after hours of diagnosis) told me they can't figure out whats wrong with, except maybe the computer being bad or it needing a reflash.
Old May 5, 2009 | 11:03 PM
myriadshalaks's Avatar
rot8ing
i looked back over your posts. you have a vacuum leak?
have you checked you airbox where the three hoses connect? i would bet that one of the plastic nipples to which they connect is broken.
or, have you replaced your cat yet?
Old May 6, 2009 | 09:19 AM
jstieber's Avatar
well i don't do work to my own car because i don't know enough to. I had a vacuum leak but that is taken care of. I also had it to a dealer and told them that i thought the cat was bad. they said my cat was fine and i don't have any extra money to buy one and without a dealer saying its bad i can't get it replaced under the emissions warranty.
Old May 6, 2009 | 09:30 AM
Nemesis8's Avatar
Bigus Rotus
You need to view the cat when it is off the car. Looking into the pipe will reveal if it is broken or clogged. A muffler shop could do this for you pretty cheap.
Are you still under warranty?
Old May 6, 2009 | 11:05 AM
^+1
Old May 6, 2009 | 11:50 AM
A re-flash won't do anything.
Have you rest the ECU since the vaccum leak repair?
You haven't had the fuel pump checked out.
I bet thats your problem. (if not low compression)
A new ECU is bug bucks. If the dealer thought a re-flash would do something they would have done it.
Old May 7, 2009 | 10:32 AM
jstieber's Avatar
I would assume that the dealer would have reset the ecu after the leak repair..? i can try it if someone sends a link on how to do it.
If the fuel pump is one of the potential problems under the p2096 code, they checked it.
I am still under warranty, its a 2004 with 56,xxx miles.
I also had a compression test done, and it didn't lose compression.
and yes i'm aware that the ecu is expensive, and also if they dealer thought the cat was a problem, wouldn't they have checked that too? i asked them to check it a few times and every time they refused to check.
Old May 8, 2009 | 11:02 PM
Jst4fun's Avatar
DIY: The Real Way to Clear the Memory
As posted by teknics
https://www.rx8club.com/showthread.p...45#post2923345
Read it, try it, see if it works.
Good luck
Old May 9, 2009 | 03:20 PM
04RX8man's Avatar
Rotary Powered Countryboy
I also say check out the cat or have a local muffler shop do it...
cliffkemp
Dec 24, 2024 10:48 AM
fistofmeat
Oct 7, 2016 12:15 PM
vapor2
Jul 9, 2016 07:35 AM
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
Tyblat
9
Aug 6, 2015 10:43 AM
