Please help with my amp installation
Old Apr 9, 2009 | 07:55 PM
dvrx8's Avatar
Exclamation Please help with my amp installation
I have 2 10's 1000w per sub and a 1600w amp i also have the LOC and everything else is connected but i just wanted to know if i was able to connect the LOC to the bose factory amp instead of the head unit.. please help
Old Apr 9, 2009 | 07:58 PM
laythor's Avatar
I zoom therefore I am.
no, you cant
but searching would explain why
Old Apr 9, 2009 | 08:02 PM
StealthTL's Avatar
Metatron
One of the (many) problems with the Bose setup is that it is 'pre-equalized' - the highs go one place, the mid goes another, and the bass signal goes to self contained 'subs' in the doors.
Old Apr 9, 2009 | 08:37 PM
dvrx8's Avatar
stealth TL so would that mean i would still have to connect it to the head unit? i saw a thread 2 days ago and someone connected there LOC to the factory amp... i was just wondering if that was right?
Old Apr 9, 2009 | 08:38 PM
dvrx8's Avatar
whats the best way to install my amp and my subs?
Old Apr 9, 2009 | 08:48 PM
BlueKnight's Avatar
TroublemakrExtraordinaire
Drive it from the head end. The wiring to the bose amp in the back is not going to give you what you need.
Old Apr 9, 2009 | 09:00 PM
dvrx8's Avatar
how would i do that? any pics and instructions???
Old Apr 9, 2009 | 09:39 PM
Tigerfootball's Avatar
Clemson, NOT Auburn
https://www.rx8club.com/series-i-interior-audio-electronics-24/speaker-sizes-harnesses-kits-etc-audio-install-reference-74664/ check out this sticky thread. It has all the information you need for your install. good luck
Old Apr 10, 2009 | 02:58 AM
forbidden's Avatar
BC
I would really, really like to hear your explanation as to why..... If the wiring goes from the head unit in the front to the Bose amp in the back, it also stands to reason that the wiring at the head unit is IDENTICAL to the wiring at the input stages of the amp in the back.
OP, what you do need to do is to connect your LOC at the output stages of the Bose amp in the rear of the vehicle, ideally on the front outputs. This has been covered many times on the forum and a search will indeed bring it up.
Old Apr 10, 2009 | 04:08 AM
AJ's Shinka's Avatar
Enthusiast
The BlueKnight has been very helpful when it comes to audio on the 8 on a couple of occasions.
Old Apr 10, 2009 | 11:31 AM
dvrx8's Avatar
Originally Posted by Tigerfootball
https://www.rx8club.com/showthread.php?t=74664 check out this sticky thread. It has all the information you need for your install. good luck
Old Apr 10, 2009 | 11:37 AM
dvrx8's Avatar
Thats what i was thinking...i wanna research some more about it? its just the fact of doing extra work if it doesnt need to be done
Old Apr 10, 2009 | 01:08 PM
firebirdude's Avatar
User and Abuser
Well he's incorrect on this case. I install for a living and have done several jobs on 8's. Including my own. You can, indeed, tap on the Bose amp's OUTPUTS with a regular ol $30 adjustable LOC and get great results. In fact, when using the cheapy LOCs it is ADVISED that you do so. The signal coming out of the headunit/going into the Bose amp is very weak. Even with the LOC cranked, I was getting a barely modest amount of signal into the aftermarket sub amp. When using the higher-end powered LOCs such as the 3sixty or LC6i, you can tap before the Bose amp and get a solid signal to your aftermarket amps. Also taking advantage of the pre-Bose non-EQed signal.
Tap off the signal going to your front door speakers and you'll have no problems.
Old Apr 10, 2009 | 01:54 PM
dvrx8's Avatar
Thanks that gives me more hope im already struggling taking the head unit out trying to find that secret bolt! lol and tapping what do you mean by that? also do u have any pics or instructions how to do all of this i just wanna make sure im doing it right.
Old Apr 10, 2009 | 01:55 PM
Socket7's Avatar
ಠ_ಠ
I agree with firebird. Unless you're replacing all your speakers, tapping into the output of the Bose amp is the best way to do things.
You need a LOC capable of working with differential signals if you want to tap directly to the head unit, and then you'll need to amplify that signal as well. It's a pain.
Old Apr 10, 2009 | 02:16 PM
User and Abuser
By "tap" I simply mean splice, cut into, attach, etc.
You have no reason to remove the factory radio. Tap into the Bose amp outputs back at the Bose amp (Next to the rear speakers) to get your signal (via your LOC). You can get your remote turn on lead from any +12 IGNITION source. The most popular choice is from the rear cig lighter in the rear center arm rest. I believe the wire is green. Run power from the battery and ground to chassis in the trunk. Done. View the sticky at the top of this forum for more info. View a few pages into it for even more info, because the original poster has stopped updating the first post.
Old Apr 10, 2009 | 02:20 PM
Socket7's Avatar
ಠ_ಠ
I don't like the cigarette lighter option, there's a switched ignition source in the Bose amp harness itself. I had a nice turn off thump while using the rear cigarette lighter. Using the switched line in the Bose amp harness made everything happy. Audio sticky will tell you what wire it is.
Old Apr 10, 2009 | 02:26 PM
User and Abuser
As I was typing that reply out, I was thinking about the IGN source in the Bose harness, but I couldn't remember the wire colors of the top of my head. Also I couldn't recall many people using that as a turn-on source. So I worded my response "the most popular choice" .
I think I'm the first one to actual poke around that harness and post up my findings in the sticky you speak of. Towards the bottom of page two.
https://www.rx8club.com/showpost.php...7&postcount=49
Old Apr 10, 2009 | 02:29 PM
dvrx8's Avatar
ok kool thanks alot!
Old Apr 10, 2009 | 02:31 PM
dvrx8's Avatar
ya i figured it wasnt necessary to take out the head unit of the same wires are in the back amp.. just didnt make any sense to me but now no more confusion lol thanks alot will will try this out!
Old Apr 11, 2009 | 12:04 AM
dvrx8's Avatar
This is the thread i saw....
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-best-route-amp-power-16217/page2/
Old Apr 11, 2009 | 12:29 AM
ZumnRx8's Avatar
RX8 & RX7 owner
i tapped into my rear speakers using a crimp clamp and installed an RCA output from there to my amp for audio source and ran the power and ground from the battery to my amp, i can post pics tomorrow if u want.
Old Apr 11, 2009 | 09:57 AM
dvrx8's Avatar
please show me ur pics! thanks
Old Apr 11, 2009 | 12:43 PM
ZumnRx8's Avatar
RX8 & RX7 owner
Old Apr 11, 2009 | 12:51 PM
ZumnRx8's Avatar
RX8 & RX7 owner
easy does it, that was my install/test pics, now the box sits behind the rear seats facing out and the wires are all wrapped in that black 1/4" split loom and hidden/ zip tied for a clean look.
