PTP turbo kit!!!!!
Old Mar 13, 2009 | 12:16 PM
05rx8mazda's Avatar
B.I.G
PTP turbo kit!!!!!
Next month my baby will undergo a implant!!! PTP turbo kit..
the only problem is the MAF thier piping is 2'' or so and they need to make the piping to the right size for the cobb unit to work.. i have the mazdaspeed cold air intake.. any information on this issue would be helpful.. I did some reading and the piping needs to be 3''
but would doing this on the ptp kit guarantee the cobb to work properly???
Old Mar 13, 2009 | 12:22 PM
pdxhak's Avatar
Official Post Whore
Congrats on the purchase! Are you doing the install yourself?
Did you checkout tdiddy's PTP build thread? Could have some answers for you.
Old Mar 13, 2009 | 01:45 PM
05rx8mazda's Avatar
B.I.G
no i didnt check it out!
no i am having them install the kit for me. i have the money in hand and they have one in stock 2 in 1 !!!
im in chicago right now but onc ei get back to austin its gonna be going in the shop.
i will look into that thread and read on it..
did he use the entire ptp kit?? oir did he build his own using ptp parts?
Old Mar 13, 2009 | 03:32 PM
chickenwafer's Avatar
Nope
AP + PTP is no go. There simply isn't enough room for the MAF housing to be accurate.
Old Mar 13, 2009 | 03:35 PM
05rx8mazda's Avatar
B.I.G
ugh i was reading that. i called up ptp and they are researching it fr me calling cobb seeing what can be done about it. but he said that it would not guarantee it would work properly.
soooo i guess i will start seeing other options =/
Old Mar 13, 2009 | 03:37 PM
Mspeedpro's Avatar
Registered Abuser
Look forward to the build... I am gonna have to check this WWP beast out.
Old Mar 13, 2009 | 03:38 PM
Nope
Honestly that won't help you. TDiddy tried to get the AP to work for a while but eventually had to go back to Int-X.
Basically, your options are:
-Int-X (somewhat hard to find now, and MazSport is outta business so no tech support from Scott)
-GReddy E-Manage Ultimate
-Custom standalone, like Haltech E8/E11v2, MoTeC ($$), etc
Old Mar 13, 2009 | 06:47 PM
pdxhak's Avatar
Official Post Whore
Check with Hymee to see if you can use his engine management I know it is going to be used for than his SC kit!
Old Mar 14, 2009 | 12:39 PM
05rx8mazda's Avatar
B.I.G
what engine management system does hymee use???????
Old Mar 14, 2009 | 12:41 PM
05rx8mazda's Avatar
B.I.G
yah i talked to my buddy and he remember that they made that pipe for tdiddy he said that they could try to extend the pipe just a bit more that it would uarantee it would work.. they reccomended me use fcon for engine management
Old Mar 14, 2009 | 01:39 PM
Scanalyser Protuner....It is a flash tuner...same requirements for the MAF to function properly
Old Mar 14, 2009 | 03:56 PM
05rx8mazda's Avatar
B.I.G
ok.. hmmm well ill see what ptp can cook up if not then i will take pauls with the mm upgrade.. pettit looks really nice but i would prefer hymee supercharger. but both are really expensive haha.. I still need to get a couple more upgrades.. just ordered
water pump!!!
clutch will be next.. just trying to find a good deal on one
Old Mar 14, 2009 | 07:08 PM
alnielsen's Avatar
The pipe they made for him was a downpipe. The ptp pipe wouldn't clear his sohn unit. Plus, he had mazsport motor mounts which moved the engine location.
Old Mar 14, 2009 | 07:51 PM
rotarenvy's Avatar
you can use a really short MAF tube and get great results. the pettit kit uses the shortest MAF around and even though they get REALLY shitty stability through it they are still driving them this way.
I don't believe you need to have a poorly functioning MAF like the Pettit kit even with a short and constricted MAF location. I have a very constricted MAF location and I get VERY stable MAF readings! I may need to do a slight recalibration compared to the STD MAF calibration however my MAF readings look brilliant compared to what I have seen from the pettit setup.
this is the MAF I use
it only has about 4" before the MAF. it immediately transitions from the 3.5" pipe to a 3" 90deg bend and goes straight into a centrifugal compressor (turbo).
according to all the so called experts this doesn't work
you don't need screens you don't need 6"+ of straight pipe before the MAF. what you need is a velocity stack and smooth airflow through the filter.
you could easily fit something like this to either the pettit setup or in the space tdiddy has.
Old Mar 14, 2009 | 09:33 PM
tdiddy's Avatar
Finally Boosted!!!!!!!
The best way to do it is to run the charge tubing down and around the radiator. Like the SFR and Mazsport type 3 kits. Then you can do whatever to the MAF and itake piping you want.
Old Mar 15, 2009 | 02:33 AM
WantedTwo's Avatar
C4 burns real good
I battled with this same problem in my thread if you remember. I was going to relocate my MAF but found out there just wasn't enough room behind the bumper. And to the guy above tdiddy, if you not running a MAF based system the car doesn't care one bit what your maf housing looks like.
Old Mar 15, 2009 | 03:06 AM
rotarenvy's Avatar
Originally Posted by WantedTwo
... And to the guy above tdiddy, if you not running a MAF based system the car doesn't care one bit what your maf housing looks like.
of course it doesn't. I only replied as people think you can't run this kit with a flash tune. most think the main stumbling block on running a flash tune with this kit is the MAF setup. there is no reason why this kit can't run a short MAF and flash tune with cob or ProTuner.
Old Mar 15, 2009 | 03:52 AM
fastlaneracing's Avatar
Rotor User
Unichip Q+ (Piggyback) will do the trick.
Old Mar 16, 2009 | 06:49 PM
05rx8mazda's Avatar
B.I.G
Yes.. I talke dto ptp and they are looking into this matter a little deaper but they need to have the car there they said..
also i am very tempted to buy paulmasoners greddy turbo with the MM upgrade.. im going to think about this the next 2 or 3 days. I really wanted a top mount turbo set up. the only thing is the cobb and the MAF being the only dilemma.
Old Mar 17, 2009 | 02:26 PM
Rotor User
http://www.tsautotronic.com/Unichip.htm
An powerfull and userfriendly piggyback with support for FI and more.
Old Mar 17, 2009 | 02:30 PM
laythor's Avatar
I zoom therefore I am.
rotarenvy, kind of an aside.. but how come you haven't opened up space in the engine bay with a battery relocation? Not worth the hassle or just didn't feel the need?
Old Mar 17, 2009 | 04:51 PM
PRX8's Avatar
Is this kit better than the Esmeril ?
Old Mar 17, 2009 | 08:02 PM
envyno1's Avatar
Originally Posted by paulmasoner
yes, by far
is this by experience?
Old Mar 22, 2009 | 07:06 AM
PRX8's Avatar
Any confirmed Dyno results, or charts against the Esmeril, will be nice to compare these kits
Old Mar 25, 2009 | 11:54 PM
Speedrx8er's Avatar
I think the BOV need to be recirculate for this setup.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Sep 27, 2015 07:49 AM
Digitz0070
Sep 25, 2015 10:58 PM
