Fuel Pressure Gauge
Old Feb 25, 2009 | 01:00 PM
baysj's Avatar
Fuel Pressure Gauge
So I just bought a fuel pressure gauge to complete my gauge pod. I did a little searching and noticed no one had posted anything about where they installed the sensor. Does anyone have any tips/tricks before I go out and cut some fuel line?
Old Feb 25, 2009 | 01:30 PM
Im_DANomite's Avatar
I love GOOOLD
PTP has a fuel pressure sensor adaptor they sell. it goes between the fuel supply line and the rail, direct snap-on fit. you might have to find some npt fittings to get your gauge's sensor to fit properly.
Old Aug 17, 2010 | 03:22 PM
RotaryMachineRx's Avatar
SPOOLN8
Zex has the same thing but I still don't like the idea of using clamps and a section of hose with it, as they require.
Completely old revival here but is this what you are talking about Ray?
http://www.compperformancegroupstore...ellineadapters
Old Aug 17, 2010 | 03:25 PM
laythor's Avatar
I zoom therefore I am.
yup, that's the one
fuel under pressure + little hose clamps = less then ideal situation
BHR has this on their site: http://blackhaloracing.com/products-...line-adapter2/
Old Aug 17, 2010 | 03:27 PM
TX
Get this instead.
Edit: Damn you laythor.
Old Aug 17, 2010 | 03:58 PM
SPOOLN8
oh nice, didn't even think to look at BHR, I'll get it shipped out with my Midpipe... woo!
Old Aug 17, 2010 | 04:09 PM
TX
That's what I did
Old Aug 17, 2010 | 05:34 PM
laythor's Avatar
Originally Posted by 9krpmrx8
Get this instead.
Old Aug 17, 2010 | 05:36 PM
laythor's Avatar
i'm always surprised a little bit when I see a turbo car without a FP gauge. I know it's doesnt fall under the "required gauges" list.. but after seeing so many people have issues that cause them to spend hours chasing down the culprit, seems to me that a FP gauge is a cheap way to go for peace of mind.
Old Aug 17, 2010 | 05:39 PM
TX
Yeah I just purchased one and the Aeromotive fuel line adapter after reading and reading about horror stories and rotary specific issues related to fuel lines, adapters, etc. Luckily the smell of fuel usually makes a fuel leak obvious.
Old Aug 17, 2010 | 06:49 PM
It's more required than an oil pressure gauge .....
Old Aug 18, 2010 | 12:00 AM
SPOOLN8
First off... Thank you Team Rx8!
Second... Especially because I will be using the stock fuel pump untill it craps out, that was my main reason for FP over coolant temp, oil temp or oil press. Besides from what I've been reading Oil temp is usually close to coolant temp and I have the AP to monitor coolant temps.
And thank you Ray for the great service I've been getting all summer from BHR!
Old Aug 18, 2010 | 12:05 AM
laythor's Avatar
really? i would think they'd be on par for the damage/headaches they can cause in a FI setup.
Old Aug 18, 2010 | 09:15 AM
We can all thank TeamRX8 for that one as he gave me (and the rest of us on this forum) the heads-up on Aeromotive's offering.
Can't take any credit for this. The credit goes to SCCA track racer & forum member "Ebb" in this thread:
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/fuel-pressure-sensor-location-127893/
I can't recall ever hearing about a Renesis that died due to a failed oiling system, but maybe I missed it. At best they are very few and far between. The rotary oil system is about as simple and trouble free as it gets. The only exception might be the extreme build FI applications.
Old Aug 18, 2010 | 09:22 AM
SPOOLN8
Do not wait until it dies on you before you make any swaps/upgrades since you will be F/I.
Noted...
and I didn't really mean untill it completely craps out but I'll be able to see when it is begining to fail and pressure begins to lower... Then It's BHR upgrade time.
Old Aug 18, 2010 | 09:54 AM
09Factor's Avatar
Original Turbo 'd Auto !!
0 psi......
Old Aug 18, 2010 | 10:49 AM
So, at what PSI will you decide that the fuel pump is no longer viable?
Had better be the first time you see it drop below normal fuel pressure
Old Aug 18, 2010 | 11:07 AM
SPOOLN8
This is what I was thinking yes... I believe 60psi ish is normal for the stock fuel pump. Now take in mind I'm an FI newb but what I was thinking was if the fuel pump begins to fail and pressure begins to reduce my AFR's should begin to lean out, which means time to replace fuel pump.
My car still has low km's and the fuel pump should still be strong (and I'm sure there are cases to contradict this) enough to keep up with the amount of fuel I will need for the stock GReddy kit. I know that if I plan to upgrade than it will be a different story, but for now I just can't afford to replace every single fix that has ever gone wrong with the Rx8.
Old Jul 24, 2012 | 08:45 PM
Brettus's Avatar
Boosted Kiwi
Wonder why BHR don't stock the adaptor any more ?
Old Jul 24, 2012 | 09:10 PM
RX8Soldier's Avatar
Time for boost...
I just purchased one off of Ray last month
Old Jul 24, 2012 | 10:49 PM
Brettus's Avatar
Boosted Kiwi
/\ yep . Thanks for that . I looked everywhere on their site plus clicked the link above but no dice .
Old Jul 24, 2012 | 11:28 PM
Brettus's Avatar
Boosted Kiwi
Originally Posted by RageBrah
even though we are gonna beat u in the rugby this weekend
JimmyBlack
273
Feb 10, 2020 10:23 PM
OnebaddRx8
Aug 25, 2019 11:34 PM
05rx8mazda
Nov 28, 2015 09:42 AM
FubarI33t
Sep 28, 2015 08:45 PM
