Installed greddy turbo kit & will not hold idle
Old Feb 16, 2009 | 12:00 AM
SHINKA RX8's Avatar
hey guys wanted to see if i can get some help. i installed the greedy turbo kit on my rx8 today with the interceptor x & i went to start the car now it will not hold idel. i got the kit used. i dont what to do. i think that it might have to be tunned so that it works, and it also sputters when u step on the accelerator. if tuning is the issue does anyone know a good dyno shop in san diego.
Old Feb 16, 2009 | 12:09 AM
05rex8's Avatar
sold the 8... :(
It's kind of hard to tell what the deal is from your post...could be anything....but my guess would be tuning. Take it to a shop and be done with it....and stay out of boost! You do not want to risk blowing the motor when it's not tuned.
Old Feb 16, 2009 | 12:18 AM
halimsteven's Avatar
when you ask questions, please be specific......
did you log in to the computer to check the INT-X? does it have the map? what type of map? is the interceptor locked? because when it was locked in mine, it couldn't idle at all.
is there any leaks? did you check all the connections and pipings?
check everything first....
steven
Old Feb 16, 2009 | 12:53 AM
SHINKA RX8's Avatar
steven
i checked all the lines that where unpluged & also all the pipes, i dont know how to check the computer. any info u could give me would help. where do i get the maps? how do i check the computer?
Old Feb 16, 2009 | 10:30 AM
MazdaManiac's Avatar
If you are not intimately acquainted with tuning the Int-X, you need to find someone that is IMMEDIATELY.
Old Feb 16, 2009 | 10:35 AM
they all think it's plug an play, without thinking about if there is a map or not....
u should go for AP which is better because you just have greddy turbo and you don't need to have someone tunes for you anymore
steven
Old Feb 16, 2009 | 11:15 AM
staticlag's Avatar
The Professor
+1 for sure
Old Feb 17, 2009 | 11:55 AM
SHINKA RX8's Avatar
the car was dropped off @ the dyno shop in santee ca. to have tuned, same place that sfr (speed force racing) has their rx8 kits tuned.
Old Feb 19, 2009 | 10:18 AM
SHINKA RX8's Avatar
So i droped off the car on monday @ the dyno shop in santee ca it is now thursday and the car is not done yet. im upset its costing around 1300.00 now. has anyone had this kind of problem with dyno tuning.
Old Feb 19, 2009 | 10:30 AM
Suave177's Avatar
When i first put the kit on my car it wouldnt hold an Idle and it was my BOV. I got the greddy RS and had to adjust it.
Old Feb 19, 2009 | 10:40 AM
staticlag's Avatar
The Professor
If they are charging $200/hr for dyno & tune then thats around 6.5 hrs, some places can charge $300/hr or more, which would be around 4 hrs. Yeah it could take 4-6 hrs to get a perfect tune, its not unheard of, the person tuning must be running into problems or going for perfection at multiple boost settings. What type of gas did you ask for, what boost settings did you ask for?
Old Feb 19, 2009 | 01:23 PM
Brettus's Avatar
Boosted Kiwi
seems like it would have been cheaper to go with the ap and ditch the x
Old Feb 20, 2009 | 10:04 AM
SHINKA RX8's Avatar
they say the interceptor x had no map & getting a hold of mazsport is not possible, but they are getting the hole thing down to perfect so that their is no issues.
Old Feb 20, 2009 | 11:06 AM
m4f1050's Avatar
Do you have stock injectors? I have a map for 93 octane, send me a PM if you need it.
Old Feb 20, 2009 | 11:13 AM
cleantune's Avatar
I'm new... I figure I'll start posting
I know this is kindof a late response- The idleing issues could be because of the MAF/ atmospheric BOV combo. the easiest way to fix this is to run a recirculating pipe from the BOV to the intake pipe after the MAF.
The MAF reads the air that goes into the system and adds feul accordingly, so it does not account for any air lost In the system, everytime the BOV releases air. Since it does not account for this, there are often super rich feul conditions between shifts and often results in stalling when coming to a fast stop.
As for the regular idling issues on start-up, the air filter may need to be cleaned?
^^ haha, I realize this probably isnt much help if you are having it tuned but, It explains exhaust flames and stalling at stoplights
Did you get the car back from the shop yet?
Old Feb 20, 2009 | 12:59 PM
baysj's Avatar
The int-x is map based, it makes no use of the maf. If he were running the cobb this could/would be an issue.
Old Feb 20, 2009 | 04:22 PM
staticlag's Avatar
The Professor
For sure, with the INTx a BOV to atmos is no problem!
Old Feb 20, 2009 | 07:12 PM
legendkurado's Avatar
steven
+1
All the maps are stored on to the laptop dongle that should have came with the int-x. Connect the int-x to your laptop and laptop dongle and check what map it is running on. If it doesn't show then you have to load the map with the Microtech software. I was lost a couple times using Microtech but eventually figured it out.
Old Feb 20, 2009 | 10:40 PM
m4f1050's Avatar
About the MAF, you *DO* need a good working MAF sensor. My MAF sensor went bad once, threw CEL and TCS light and it would not idle, I had to give it some gas to keep it running. It is tuned with MAP but the stock computer requires the MAF sensor.
Old Feb 24, 2009 | 09:55 AM
SHINKA RX8's Avatar
ive got the car back n it runs great they made the stock computer run the cycle of the injectors n the interceptor runs the rest. they were working with microtech to get the car to perfect n i got to tell u guys they did a great job only 5lbs of boost because i have no boost controller but 260hp & 216tq, i think those are good numbers.
Old Feb 24, 2009 | 11:18 AM
Red Devil's Avatar
Those are really good numbers...what was your baseline hp?
Old Feb 24, 2009 | 12:46 PM
SHINKA RX8's Avatar
i had it dyno with obx headers/exhaust/pully/intake @ 206 hp & 141tq. before the turbo upgrade i plan on upgrading the injectors/boost controller & hks ignition, to get a little more power in the future.
Old Feb 24, 2009 | 04:17 PM
those are great numbers for 5psi... do you know what dyno they (the shop) are using?
Old Feb 25, 2009 | 11:03 AM
SHINKA RX8's Avatar
dynojet dynometer.
Old Feb 25, 2009 | 11:16 AM
AngryBumblebee's Avatar
The Bawss
Dynojets give a higher rating than Mustang, but those are still great numbers. The torque is a huge improvement over stock! congrats!
Mxttz0r
Jul 5, 2019 03:19 AM
jay_tibo
22
Sep 13, 2016 08:10 PM
RicerX1
Jan 11, 2016 05:59 PM
k4thomas
Aug 5, 2015 03:03 AM
