Help! Voltage Problem? (P0428)
Old Feb 6, 2009 | 10:51 AM
Aceninja's Avatar
Question Help! Voltage Problem? (P0428)
So my check engine light came on yesterday and after I took the car to autozone for a check engine light diagnosis, the following came up:
OEM Number to Cross: P0428
The PCM has determined that the voltage signal from the catalyst temperature sensor for bank 1 is too high for the current engine operating conditions. (bank 1 identifies the location of cylinder 1, while bank 2 identifies the cylinders on the opposite bank)
Since I am kind of technologically challeneged, I was wondering if anyone could translate that into plain english for me? I am guessing my engine is running hot? But the temp sensor seems normal.... Any help will be sincerely appreciated!
Old Feb 6, 2009 | 11:17 AM
EDZRIDE's Avatar
2005 White GT
Sounds like a cat or sensor issue.
Old Feb 6, 2009 | 11:28 AM
Cat might be clogged.
What year is your car? Mileage?
Cat is covered under emissions for 8 years, 80,000 miles.
Old Feb 6, 2009 | 01:23 PM
Aceninja's Avatar
Car Spec
It's a 2004 RX8 with 30,000 miles. My warranty is no longer in effect, but it's nice to hear about the 8 year CAT warranty . Has anyone ever come across this problem before?
Old Feb 6, 2009 | 01:27 PM
Likely a sensor problem with the rear O2 sensor?
Old Feb 6, 2009 | 01:29 PM
yeah, maybe it's gunked up or something knocked it loose?
crawl under there and take a look.
Any other codes come up or just the 0428?
Old Feb 7, 2009 | 01:20 PM
Aceninja's Avatar
No more codes, jus that one. Come to think of it I think I did scrape the cars bottom while backing out recently...I will check it out! Umm what exactly am I looking for btw, any specific location for the O2 sensor?
Old Feb 7, 2009 | 01:36 PM
Likely the narrow band sensor on the midpipe.....
It actually sticks down and is easily hit...god only knows why they put it there
Brettus
Series I Engine Tuning Forum
46
Apr 19, 2024 06:28 AM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Vedivan1
Sep 18, 2015 12:39 PM
