Turbo Efficiency Range for RX-8
Old Jan 16, 2009 | 09:11 PM
zoom44's Avatar
Ok this thread was prompted by T-Rex-8's comment i have quoted below
Originally Posted by T-ReX-8
All the RX8 community needs is nice 5x trim sized, externally gated (for the serious) or internally gated (for the wussy) setup made for quick spool to deal with the RX8s low end power issues and getting the turbo further into its sweet spot. No more of these oversized turbos the RX8 can barely spool, do these vendors realize how far out of the efficiency range all of these turbos are being ran?
Id like to see posted here the compressor maps for the various Turbos in the available turbo kits out there so we can have a discussion on which T is really the best suited for the 8 . Also Id like to see T_Rex post up what he thinks is the correctly sized Turbo.
Lets compare. I don't have time right now to collect them myself from the various threads as im due in the living room for a butt whooping at GO FISH
Old Jan 16, 2009 | 09:19 PM
Kane's Avatar
Senior Member
Where is that pic of the three turbo's Jeff made?
I can never find it when I want it.
This seems kinda stupid unless we all ahve an equal Mass Airflow we are going for.
So to start off - I say the RX8 range should be - 7 lb/min to 55 lb/min would be our operating range... seem fair?
Old Jan 16, 2009 | 09:26 PM
05rex8's Avatar
sold the 8... :(
so which kit that vendors are providing has the oversized turbo's that t-rex is talking about?
Old Jan 16, 2009 | 09:43 PM
Kane's Avatar
Senior Member
Ok - so who wants to do the math?
7 lb/min at 1500 RPM = what Pressure Ratio?
50 lb/min at 9000 RPM = what Pressure Ratio?
Assume a VE% of 1.
Old Jan 16, 2009 | 09:49 PM
zoom44's Avatar
i thought you were the math guy?
05rex lets deal with the message and not the messenger please.
Old Jan 16, 2009 | 09:56 PM
zoom44's Avatar
good read which is on topic
http://www.rbracing-rsr.com/turbotech.html
edit: another helpful link
http://www.automotivearticles.com/Turbo_Selection.shtml
Old Jan 16, 2009 | 09:57 PM
Kane's Avatar
Senior Member
Aww come on I am sitting on a cot right now...
I might do it after dinner if no one else is gonna..... lazy!
Old Jan 16, 2009 | 10:03 PM
Brettus's Avatar
Boosted Kiwi
I doubt there is a turbo that can do it . The 3071 does not even come close to staying in its efficiency range when pushed
Would like to see maps for the Esmeril and Mazsport turbos to compare ....
Old Jan 16, 2009 | 10:10 PM
Kane's Avatar
Senior Member
50 is North of the 3071R's range; I am just saying that was an absolute maximum for our treet driven RX8's.
Old Jan 16, 2009 | 10:11 PM
Kane's Avatar
Senior Member
PR Compressor = (boost - PD + ambient)/ambient
Ideal Temp Out =[(Tin + 460) * PR^.283]-460
Actual Temp Out = [(Tout Ideal – Tin) / Efficiency] – Tin
Density Ratio = PR * [(Tin + 460)/(Tout+460)]
Engine Displacement +[(#Cyl)*(Stroke)*(Bore)^2]/1.27
VFR100% = [(Disp)(RPM)]/ 3456 or 1728 rotary
VFRactual = (VFR100%)(VE)
MFR - NA = [(2.703)(PAmbient)(VFR)]/[TAmbient + 460]
MFR - FI = (MFR-NA)(DR)
Old Jan 16, 2009 | 10:27 PM
Flashwing's Avatar
3-wheeler
Everything you're asking for has already been answered....
The best turbo for the RX8 would have a custom turbine housing and we already know which turbo has that.
Huh? There's two sides to a turbo and you're forgetting the other side.
Old Jan 16, 2009 | 10:30 PM
Kane's Avatar
Senior Member
For the 50 lb/min goal.
VFR100% = [(Disp - 80ci)(9000)]/1728 rotary = 417 CFM
MFR - NA = [(2.703)(14.7PSI)(VFR - 417)]/[TAmbient-80 F] + 460] = 30.6 lb min
MFR - FI = (30.6 lb min) * Density Ratio of 1.68 = 51.4 lb/min
PR Compressor = (Boost (Say 16 lbs) - (Pressure Drop-2 PSI) + ambient)/ambient = 1.95
Ideal Temp Out =[(Tin of 80F + 460) * PR^.283]-460 = 192 F
Actual Temp Out = [(Tout Ideal - Tin) / Efficiency (Assume 70F)] + Tin = 240F
Intercooler Efficiency of 70% = 168 F
Density Ratio = PR * [(Tin + 460)/(Tout+460)] = 1.68
Old Jan 16, 2009 | 10:32 PM
Kane's Avatar
Senior Member
So mark a 1.95 PR and 51 lb/min of air on the chart.
Now someone else do the 10 lb/min one.
Actually the PR would have to be higher since the VE isn't one.... but whatever. We could just round them to PR of 2 and 50 lb/min... this whole argument can get crazy otherwise.
Old Jan 16, 2009 | 10:35 PM
zoom44's Avatar
Originally Posted by Flashwing
Everything ....
you have missed the point entirely. if you can add a map or other info please post. if you can factually debate for or against a particular turbo please post. if you cant dont.
Old Jan 16, 2009 | 10:36 PM
zoom44's Avatar
yes exactly kane.
Attached Thumbnails Turbo Efficiency Range for RX-8-compress_comparo_20g_18g_3071.jpg
Old Jan 16, 2009 | 10:48 PM
Kane's Avatar
Senior Member
Ahh **** it.
For the 7 lb/min goal.
VFR100% = [(Disp - 80ci)(1500)]/1728 rotary = 69.4 CFM
MFR - NA = [(2.703)(14.7PSI)(VFR of 69.4)]/[TAmbient-80 F] + 460] =5.1 lb min
MFR - FI = (5.1 lb min) * Density Ratio of 1.34 = 6.8 lb/min
PR Compressor = (Boost (Say 7 lbs) - (Pressure Drop-1 PSI) + ambient)/ambient = 1.41
Ideal Temp Out =[(Tin of 80F + 460) * PR^.283]-460 = 135 F
Actual Temp Out = [(Tout Ideal - Tin) / Efficiency (Assume 70%)] + Tin = 158F
Intercooler Efficiency of 70% = 110 F
Density Ratio = PR * [(Tin + 460)/(Tout+460)] = 1.34
Old Jan 16, 2009 | 10:51 PM
Kane's Avatar
Senior Member
So we want a turbo that will boost to 7 PSI at 1500 RPM's and Hold 16 PSI at Redline Efficiently.
So
7 lb/min @ 1500 = PR of 1.5
50 lb/min @ 9000 = PR of 2
Now go find this magical turbo that will be efficient in this range......
Or more realistically - go find the one that is the best fit.
Old Jan 16, 2009 | 10:57 PM
Brettus's Avatar
Boosted Kiwi
So
I have no idea what you did there but it looks impressive
Old Jan 16, 2009 | 11:06 PM
zoom44's Avatar
So
Old Jan 16, 2009 | 11:12 PM
Kane's Avatar
Senior Member
And what have we learned about our huge oversized penile compensating turbo's?
Old Jan 16, 2009 | 11:16 PM
zoom44's Avatar
well until we get a couple more maps nothing except that i got you to do the math by leaving and getting my *** kicked at candy land by a 4 year old. totally worth it.
im goin to watch BSG now so if there is more to do.....
Old Jan 16, 2009 | 11:18 PM
Kane's Avatar
Senior Member
Even the big boys won't look too bad... assuming you can spool 'em which we can do better than pistons... it will just shift right some.
Old Jan 16, 2009 | 11:22 PM
Brettus's Avatar
Boosted Kiwi
I remember seeing some maps in one of the esmeril threads - now how many pages is that now ????
Old Jan 16, 2009 | 11:57 PM
dont you have software that does that?
Old Jan 16, 2009 | 11:58 PM
paulmasoner's Avatar
Asshole for hire
well first i think 55lb/min is a bit of a stretch for the typical street car. Thats around 490 at the flywheel
I think 40-45lb/min is a bit more realistic. 44lb/min is closer to 400 at the fly
^^this assumes AFRs of 11.2-11.5
that puts the 3071R at an almost perfect match. I dont think you'll find a turbo that will spool like everyone wants and still play nice at 55lb/min.
i couldnt find the Esmeril compressor chart, if it was ever posted - i think it's gone now.
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
