Installed Greddy Turbo....won't start
Old Jan 4, 2009 | 05:36 AM
DynamicDookie's Avatar
Just had a greddy turbo installed. Did fix 2 and I'm using the AP for management. The shop has a lot of rotary experience and has turbo'd several 8s. Changed the plugs wires and coils.
The engine won't kick over. The starter sounds like its struggling/surging and I guess it could be the starter, but it was fine before the install. Fuses are all good. Swapped the battery. We're getting good spark and gas is flowing. No codes on the AP (except the mysterious P0039).
Any ideas? Grounding issue?
....we also tried getting it started with the FI map and the stock map, same result.
Old Jan 4, 2009 | 05:50 AM
StealthTL's Avatar
Metatron
Try the twenty stomp reset, the ignition could be wack if the sensor got moved.
S
Old Jan 4, 2009 | 12:25 PM
S
which sensor? ....we tried the the 20 stomp too.
Old Jan 4, 2009 | 12:44 PM
04RX8man's Avatar
Rotary Powered Countryboy
so it cranks just seems to b slow cranking? do u have the upgraded starter?
Old Jan 4, 2009 | 12:50 PM
Brettus's Avatar
Boosted Kiwi
try push starting it ....
Old Jan 4, 2009 | 01:03 PM
new starter and battery a while back. it's weird because the car cranked fine a few days ago.
Old Jan 4, 2009 | 01:04 PM
thought about that. might be our last resort.
Old Jan 4, 2009 | 01:30 PM
gregs's Avatar
Pull My Finger
was there anything else you installed other than the standard greddy supplied parts? just trying to figure out what areas you might have been in that may be a possible loose connection..just want to get it clear as well is it no crank no start or crank no start?
Old Jan 4, 2009 | 02:13 PM
crank, no start. greddy kit with mazsport cai and ic, hks sqv and new clamps couplers.
it does sound like the starter is slow, but a few days ago it was fine. just don't want to spend $350 on a new starter when it could be something else.
I thought maybe it could be a short somewhere, but the fuses are fine and the only things disconnected were the air pump and the maf sensor.
Old Jan 4, 2009 | 02:20 PM
Brettus's Avatar
Boosted Kiwi
Just push start the biatch - that will eliminate anything non starter related as a problem ...
If it goes you know it is your battery or starter
Old Jan 4, 2009 | 03:00 PM
hopefully no major leaks, but I think it might be the only way.
Old Jan 4, 2009 | 04:10 PM
It will start even with a huge leak...so that isn't your problem...did you check the OMP connector and the throttle, ECT and the main sensors?
Check the battery voltage...I've seen people swap a bad battery for a marginal one and wonder why it didn't change anything
It is easy to flood them trying to start them if everything isn;t perfect...so check the plugs. You are sure you have good fuel pressure and injectors are stock?
Just start with what you know is good...and start checking everything else till you figure it out
Old Jan 4, 2009 | 05:09 PM
04RX8man's Avatar
yeah push starting will let u know if it's a starter or not if it fires up rather easily it's prob a battery or starter!! if not htere is another prob...
So it has never been started since the turbo was installed?
Old Jan 4, 2009 | 05:53 PM
...So it has never been started since the turbo was installed?
Nope, it was at the shop for the install and this was the first attempt at starting the car with the turbo.
Old Jan 6, 2009 | 02:23 AM
the starter is fine, it was the battery. brand new red top...go figure. car starts fine and no oil leaks.
thanks for the sanity check guys.
Old Jan 6, 2009 | 02:58 AM
AngryBumblebee's Avatar
The Bawss
Good to hear, a car not starting after spending that much money is frustarating. make sure you get the MM tunes for that turbo kit Jeff is a genius!
Old Jan 9, 2009 | 06:37 PM
04RX8man's Avatar
good thing nothing major!
Mxttz0r
Jul 5, 2019 03:19 AM
jay_tibo
22
Sep 13, 2016 08:10 PM
UHATEIT
Dec 10, 2015 02:57 PM
poppinparker
Aug 10, 2015 09:20 AM
dbarber
Jul 25, 2015 01:34 PM
