New MazdaManiac BASE Calibrations
Old Dec 26, 2008 | 01:12 AM
  #201
MazdaManiac's Avatar
Originally Posted by neXib
Cool. I'll look at the values when I'm logging. I can write if I want the cruise "fattened up" in the additional info section if you read those every time?
Just get the logs. When you send your e-mail, add a note that you want "CAT-safe" values, and I'll try to get them as close as I can.
Old Dec 26, 2008 | 05:05 PM
  #202
Mr.&Mrs.Magic's Avatar
just clarifying the typo error
you want 2nd and 3rd wot not 3rd and 4th. I know you want 2nd and 3rd but just getting this possible question from some else out of the way.
12) Take your RX-8 to a safe section of completely open highway where you can get the vehicle up to redline in 3rd gear without being disturbed.
13) Bring the vehicle up to 3000 RPM in 2nd gear. (1st gear for the 4-speed automatic transmission.)
14) Press the "OK" button again to start the data-log and depress the gas pedal all the way to the floor.
15) When you hear the redline beep, shift to 3rd gear (2nd gear for the 4-speed automatic transmission) and continue to redline again, then release the gas pedal.
16) Press the "OK" button again. You have just created your third data-log of the engine's Wide Open Throttle performance.
Send an e-mail using THIS LINK, attach the three data-log files you have just created (one at idle, one at a steady cruise and one at WOT through (3rd and 4th gears to redline)) and provide the answers to these questions:
One more thing I am currently getting 32 mpg on the freeway with a afr in the upper 14's. I'll shoot video for anyone who doesn't believe me. I have to assume the AP is wrong??? tire size 225/45/18
Old Dec 26, 2008 | 05:10 PM
  #203
neXib's Avatar
I think most people calculate mpg based on actual numbers in their car when they refuel
Old Dec 26, 2008 | 05:42 PM
  #204
kersh4w's Avatar
Hit & Run Magnet
Originally Posted by 05rex8
so what was the point of getting the AP if you didn't have MM make you any calibrations?
the mm maps?
the fans kicking on sooner? i think the OMP is modified as well.
Old Dec 26, 2008 | 07:24 PM
  #205
hakuna matata!
but you never got a custom calibration from him....? the maps that came with the AP were base and for use in his calibration process....
Old Dec 26, 2008 | 07:34 PM
  #206
05rex8's Avatar
sold the 8... :(
did the old base maps change the OMP and fans? if not, talk about a waste for you Kersh.
Old Dec 27, 2008 | 01:26 AM
  #207
hakuna matata!
back to 11.1 at WOT.. eww
Old Dec 27, 2008 | 02:12 AM
  #208
Yes. Typo the second time.
2nd gear and 3rd gear are on two separate fuel maps.
Redline in 4th would be very, very fast.
It is possible to get an instantaneous MPG like that.
Your average won't be as good.
You should get decent mileage once the calibration is complete.
Well, yeah. That is expected. We fix that next once we have the injectors/MAF set up.
Old Dec 27, 2008 | 02:16 AM
  #209
Easy_E1's Avatar
With the latest MM tune I have,, I've increased my mileage by 17 miles to a 1/4 tank. Maybe because I'm not shooting N2O into the intake with this tank so far.
Old Dec 27, 2008 | 09:16 AM
  #210
09Factor's Avatar
Original Turbo 'd Auto !!
The latest I have went up 11 mpg @ 1/4 tank with a good time being in boost.
Old Dec 27, 2008 | 11:30 AM
  #211
hakuna matata!
My last tank was exactly 12.01 mpg. 175 miles to 14.5 gallons. Awesome, eh?
Old Dec 27, 2008 | 12:13 PM
  #212
ShellDude's Avatar
weeeeeeeeee
last sample for me:
city only driving - 218.4 miles using 14.136 gallons of gold - 15.45 mpg
Fairly consistent too. I get on the highway and keep her there and the numbers change dramatically, to the tune of:
highway only - 330.2 miles using 14.452 gallons - 22.85 mpg
stock 04 4AT - factory everything still, except my MM AP.
Old Dec 27, 2008 | 01:48 PM
  #213
Easy_E1's Avatar
Jeff hard at work tuning on MY AP. Sorry folks. But being local has it's privileges.
Besides who else is going to lay is car on the line for testing?
Ray waiting patiently on some up dates for his.
Here is mine, 09Factors Greddy Turbo 4 Port AT, Jeff and him just got back from doing some tuning. and Charles R. Hill's car,,,
Old Dec 27, 2008 | 01:58 PM
  #214
ShellDude's Avatar
weeeeeeeeee
I'm surprised no one bought him an AspireOne for Christmas! It's much nicer than that little 701 he uses.
Old Dec 27, 2008 | 02:30 PM
  #215
05rex8's Avatar
sold the 8... :(
Ray needs clear corners and tint
Old Dec 27, 2008 | 02:50 PM
  #216
I don't want nice - I want expendable.
The 701 is practically disposable, which is the right device for the environments in which I work.
Thanks for the thought, though!
I'm thinking about stepping up to one of the 900 series with the bigger display and larger SSD.
Old Dec 27, 2008 | 03:03 PM
  #217
MM where did you get the usb cable attached to the AP in pic #1. Will it plug into the obd2 thingy
Old Dec 27, 2008 | 03:35 PM
  #218
Its just a regular USB-A to USB-mini cable.
It probably came with a camera or something.
You can get it at Best Buy or Fry's Electronics or something similar.
Radio Shack probably has it, too.
It can be used just like the cable that came with the AP.
Old Dec 29, 2008 | 12:31 AM
  #219
hakuna matata!
Ay.. I'm using the exact same cord Jeff is using. I got mine from a Sony camcorder.
Since my OBD2 port SUCKS.. I have to use a bungee rope thingy to hold up the obd2 dongle securely to the obd2 port, I had my AP OBD2 dongle plugged into the bungee for a few hours and it literally bent the original usb mini connector on the dongle.. so that cable is worthless now.
Old Dec 29, 2008 | 01:25 AM
  #220
Just use tape or Velcro.
Old Dec 29, 2008 | 09:40 AM
  #221
09Factor's Avatar
Sorry I couldn't hang around longer X-mas Eve.
Being local does have it's perks.
Old Dec 29, 2008 | 11:05 AM
  #222
onefatsurfer's Avatar
White is purdy...
Sent in my stuff, now waiting on the calibration. I'm not in any rush, since I know the holidays are busy for everyone, including me.
Old Dec 29, 2008 | 11:12 AM
  #223
I8U's Avatar
I8U
Jeff, you do realize you're gonna be swamped with orders in the very near future...I know where my income tax refund is going!
Old Dec 29, 2008 | 11:47 AM
  #224
Bring it!
Now that I have this system worked out, I can get through a dozen or more calibrations in a day.
Old Dec 29, 2008 | 11:48 AM
  #225
shaunv74's Avatar
Power!!
Just did my first drive cycle on the base map. With the temps around 40F out I should be able to get my second in this afternoon. :P
