New MazdaManiac BASE Calibrations
Old Jan 3, 2009 | 12:50 AM
  #276
if / when Jeff cooks his PCM due to reflashes, then we can worry.
Old Jan 3, 2009 | 12:53 AM
  #277
MazdaManiac's Avatar
Precisely.
I keep a couple of extra PCMs around, but I'm well over 500 flashes on this one with no issues.
Old Jan 3, 2009 | 12:54 AM
  #278
paulmasoner's Avatar
Asshole for hire
yeah i doubt many/any others will be coming close to that much..
Old Jan 3, 2009 | 01:02 AM
  #279
I sure hope not.
That is a LOT of e-mail from me!
Can you imagine?
If HALF of my customer base required only half as many flashes each to get it right, I'd have to email out over 5000 calibrations!
Old Jan 3, 2009 | 01:07 AM
  #280
Asshole for hire
but your all streamlined now thats makes it easy right? lol
Old Jan 3, 2009 | 01:11 AM
  #281
Yes!
I just sent out 100 calibrations with my mind!
I sent out another 50 while I typed that!
Old Jan 3, 2009 | 01:21 AM
  #282
Jasonawojo's Avatar
And if it took 250 adjustments, fuel cost for tuning might actually need it's own spot on the budget.
Ok, cool beans. Jeff, how many stages come after 4.0.2?
Old Jan 3, 2009 | 01:23 AM
  #283
That depends. If your v4.0.2 is f-ed up, it might be two or three more.
Normally, there is only one more.
v4.0.3 is the "tuned" version once the MAF/injectors thing is worked out.
Did we go through the whole thing correctly, or did I still cook you by mixing and matching logs against the wrong calibration?
You are the guy that wanted to update even though you were already properly tuned on the v3 set, right?
Old Jan 3, 2009 | 01:33 AM
  #284
hakuna matata!
Woo.. so I should be expecting my "tuned" version soon?
Old Jan 3, 2009 | 01:38 AM
  #285
You do realize this is a holiday week and its the weekend, right?
Old Jan 3, 2009 | 01:44 AM
  #286
hakuna matata!
I lost track of time on new years eve, forgive my insolence master.
Old Jan 3, 2009 | 01:46 AM
  #287
Jasonawojo's Avatar
Yea I'm that guy. I've been wondering if it wouldn't have been easier for you just to slightly edit the v3 one? You had said 0.5 leaner would make it perfect.
I'm not sure if the 4.0.2 is "bad" or not, as the cruise and WOT trims are positive a few. The idle ltft on my log is +20 though.
I originally sent proper logs for 4.0.0, then decided against going through the work to redo it. Then after discussing my v3 tune on the forum you said to send you logs from it so I sent you idle and cruise logs from my v3 tune. Originally you sent me a 4.0.1 based on those, but then after I PMed you about it said to disregard the 4.0.1 tune you sent me and that I didn't need to do anything on my end. Then I got the 4.0.2 when a few others did.
Old Jan 3, 2009 | 01:48 AM
  #288
I've been in a constant fog since the 25th, so no worries.
I'll figure it out (hopefully).
Old Jan 3, 2009 | 09:40 AM
  #289
alienRX8's Avatar
Boosted!!!
By the way Jeff can we go postal on the postal service?? I still have not received the package you sent me with the injectors and the couplers
I think USPS wants me to suffer though christmas
Old Jan 3, 2009 | 10:13 AM
  #290
That is getting ridiculous.
I'll just send you another set via UPS and you can send me back the first one once it finally gets there.
Old Jan 4, 2009 | 01:16 PM
  #291
out in the garage right now, about to do a DataLog but ran into a problem.
The car was idling as I was setting the Data Log List when the AP told me it could not connect to ECU (car was on) and the Tach started fluctuating between 500 - 2500 rpm. (though the car's idle was unchanged)
turned the car off, unplugged the AP and plugged it back in. The tach is steady but Traction Controll Off light is still on.
Now have the following Codes:
PCM U0073
IC: U1900
EPS: U1900, U0073
RKE: U1900
Dont want to reset the codes as it'll reset the ECU and I'll lose the fuel trims. hmmm...
Gonna go google search those and see what I come up with.
Old Jan 4, 2009 | 01:21 PM
  #292
laythor's Avatar
I zoom therefore I am.
I had the same traction control light come on after I upgraded the flash on the AP. Turned off the car and turned it back on and light has not come back on since. I did not get any cel codes with the dsc light.. so not sure what's going on with that Jedi.
Old Jan 4, 2009 | 01:25 PM
  #293
ShellDude's Avatar
weeeeeeeeee
Here's what I got for ya, Jedi:
U0073 CAN system communication error • PCM
U1900 CAN system communication error • DSC HU/CM
Sounds like you got a BSOD.
Check out:
http://foxed.ca/rx7manual/2003mazdar...html#wp1025486
  #294
traction control light now off. (turned car off and on again)
now to see if my AP is logging properly. First attempt had it logging stuff that I hadn't asked it for.
Old Jan 4, 2009 | 01:26 PM
  #295
thanks Shell.
BSOD?
Old Jan 4, 2009 | 01:30 PM
  #296
car seems to be fine, 1st Data log worked. Gonna go do my driving log and then reset the codes.
Wish me luck boys!
Old Jan 4, 2009 | 01:32 PM
  #297
ShellDude's Avatar
weeeeeeeeee
Windows Blue Screen Of Death
From 4,500 miles away in an armchair it sounds like your PCM rebooted or crashed or something odd along those lines.
I wonder if your dongle caused a short...
Old Jan 4, 2009 | 02:02 PM
  #298
BSOD; damn it, I know that one! Just thought you were making up some other weird AP accronym
data logs came out well, gonna send them to jeff along with the 11 deadly questions and then off to reset those codes.
how's the weather 4500 miles from here?
Old Jan 4, 2009 | 02:33 PM
  #299
L337fpc's Avatar
ლ(ಠ益ಠლ)
My car also had the DSC code come up just a few hours ago on the highway. That and my ABS light came on. I couldn't engage/disengage my DSC nor my cruise control. I pulled over on the highway and cycled the car, all the codes cleared and lights cleared.
I'm still running the base 4.0.1 maps...and I'm still running uber rich, like high 13's @ idle and in most common driving.
Old Jan 4, 2009 | 02:53 PM
  #300
ShellDude's Avatar
weeeeeeeeee
balmy 41 today... here are the conditions at my house, literally...
http://weather.shellware.com/Weather.aspx
