Derex'8 Turbo Setup
Old Nov 25, 2008 | 10:56 PM
Derex'8's Avatar
ReDuX
Derex'8 Turbo Setup
Well things are finally winding down piecing this kit together. Below are some pics of the components. and a Parts List I've compiled of mostly everything I've bought
Parts List
Master Powers T70 Turbo Did alot of research on this one and was surprised to alot of people run these and hear nothing but good things.
Turbine Wheel:
-Exducer Diameter: 2.53"
-Mayor Diameter: 2.91"
Compressor Wheel:
-Exducer Diameter: 2.72"
-Mayor Diameter: 3.58"
Turbine Housing:
-A/R: .96
-inlet: T4
Compressor housing:
-A/R: .70
-Air Inlet: 4.00"
Oh and for all you naysayers click here
One-off Hot side Piping courtesy of TIM from SFR
Mishimoto Bar & Plate 24.5" x 11.75" x 3
IC piping
2 750cc RC injectors
1 Greddy oil pan
Snow Alky/water injection
BHR TB spacer
BHR ignition not yet just awaiting on a long list of pre orders
Synchronic BOV
Tial 46mm Wastegate
AEM Tru Boost Gauge
Old Nov 25, 2008 | 10:57 PM
Derex'8's Avatar
ReDuX
Parts List cont.
Oil filter adapter
OEM Exhaust Gasket
3" Black 90 Degree Elbow w/1" Nipple for BOV/Diverter Valve
7 T-Bolt Clamp - 2.75"
2 90 Degree 2.5" ID to 3" ID Transition Silicone Elbow
2 Hump Connector 2.50" - silicone
1 Transition Hose 2.5" to 3" - Silicone
1 DRAIN Custom Oil Return Line
2 Straight 1/2" NPT to -10 AN
1 Aluminum - Oil Drain Flange (T3/T4)
1 Oil Return Gasket - T3 or T04
4 T-Bolt Clamp - 3.25"
1 Garrett Turbine Housing Heatshield, Stainless
2 QuickTap-CompHSG
ATP-SIL-027 Straight Connection Hose 1.25" " ID Silicone
3 3" V-Band Clamp
1 4" T-Bolt Clamp
3 3.50" T-Bolt Clamp
4 3" T-Bolt Clamp
1 3.00" (76mm) OD 90 Degree Elbow Pipe - Aluminum
1 3" to 3.50" (76mm to 90mm) Straight Transition
2 Thermo-Tec Adhesive Backed Heat Barrier 12"x2
1 Graphite Black 1" x 50' Thermo-Tec Exhaust In
2 Thermo-Tec Heavy Duty Thermo-Shield 1 -1/2" X 15’ roll
1 Auto Meter Universal 52mm Black Gauge Pod
Old Nov 25, 2008 | 10:59 PM
hakuna matata!
interesting.
ems choice?
Old Nov 25, 2008 | 11:04 PM
Derex'8's Avatar
ReDuX
I already have the Cobb AP along w/MM's turbo maps
Installed already is the boost controller, alky/meth reservoir, and battery. Will be installing my injectors and mounting alky pump tomorrow.
I forgot also awaitng my turbo bracket to come in and install is a go
Old Nov 25, 2008 | 11:11 PM
hakuna matata!
cool, interesting turbo choice.. we'll see how it fairs.
subscribed.
Old Nov 25, 2008 | 11:17 PM
Derex'8's Avatar
ReDuX
Thanks, Yeah we'll see. They come w/a 1 year warranty also.
If worse comes to worse I can easily pick me up a reman'd garret unit
Old Nov 25, 2008 | 11:27 PM
that's sick bro... cant wait for updated pics when you get building!
Old Nov 25, 2008 | 11:45 PM
NgoRX8's Avatar
that's a nice list of parts man. very thorough. Good luck with the install!
Old Nov 25, 2008 | 11:49 PM
TopGear8's Avatar
mkuhnracing.com
Turbo parts all over the floor of your daughters room! Haha very nice.
Old Nov 25, 2008 | 11:51 PM
that's a hell of a list you got there, can't wait to see this project come to life
Old Nov 25, 2008 | 11:52 PM
nuke0907's Avatar
Never Blend In
awesome derek. maybe you can help me get the rest of my parts together?
Old Nov 26, 2008 | 12:07 AM
Derex'8's Avatar
ReDuX
^^^ yeah man definately. This has been quite a roller coaster I will tell you that won't even mention the # of times I ordered things, and finally got it delivered only to find out it was the wrong size (Yeah I'm talking about those damn oil and drain fittings) Overall it's been cool, just hoping & praying when it comes time for install everything fits like a glove
Old Nov 26, 2008 | 12:09 AM
Kane's Avatar
Senior Member
Nice man; looks good so far!
Now get it into the car... that part is fun.
Old Nov 26, 2008 | 12:23 AM
05rex8's Avatar
sold the 8... :(
did you fabricate a turbo manifold for it?
Old Nov 26, 2008 | 12:38 AM
pianoman's Avatar
I too am interested in this same question..
Old Nov 26, 2008 | 12:47 AM
NgoRX8's Avatar
it appears to be the SFR turbo piping
Old Nov 26, 2008 | 01:03 AM
636's Avatar
636
Rice Police
How much power are you expecting from this set up? Are you going to increase timing and run meth?
Old Nov 26, 2008 | 01:43 PM
chickenwafer's Avatar
Nope
Good luck getting that intercooler in there, it's pretty tall so you'll have to either cut part of your crash bar or angle the intercooler.
Also you may need jumper harness' for the RC injectors. The RX-8 connector is different than the "standard" J-Tronic connection.
Old Nov 26, 2008 | 01:55 PM
NgoRX8's Avatar
intercooler could fit behind the rebar. but i wonder how the maf setup will react since the placement of the turbo is basically the same as tdiddy's ptp setup.
Old Nov 26, 2008 | 07:42 PM
gregs's Avatar
Pull My Finger
looking really good i cant wait to see more progress, glad to see more boosted rx8's coming out
Old Nov 26, 2008 | 07:58 PM
Derex'8's Avatar
ReDuX
Jumper harness are you referring to the obd clips that came w/my injectors, I really hope so, because thats what I used and had to splice & solder.
What an exhausting day spent the whole day removing the uim and getting one injector installed Them things are a bitch w/out the right tools..and don't get me started on the harness. Went ou this evening & acquired some more hardware ( o rings, bolts, etc) and picked up a 1/4 socket wrench & set for all those damn 10mm bolts (that are so agonizing to get to) Expecting things to move alot faster now w/this.
The hot side piping is indeed from SFR
As for the IC it just so happens to be the exact same measuremnts as the esmeril so we'll see how that works out...I plane to mount it the exact same way right in the grill area...
Old Nov 26, 2008 | 08:03 PM
Derex'8's Avatar
ReDuX
My Maf setup will actually be a lil different, per Jeff's instructions my length of pipe before & after the maf should yield me stable conditions.............HOPEFULLY !!
Old Nov 26, 2008 | 09:17 PM
NgoRX8's Avatar
awesome! good luck with it man. Have fun!
Old Nov 27, 2008 | 03:33 PM
Derex'8's Avatar
ReDuX
Well finished up the injector install today and got things up & running but looks like a have a small vaccum leak somewhere don't even no where to begin to start? Any Suggestions anybody? Checked and rechecked all hose connections.
My boost gauge is reading -12 to -14 @ idle and my maf g/s is 3/4 as it was 5/6 before. Car wouldn't even idle, but tuned for the leak and set my maf calibration @ idle down. Now it can idle but rough, thinking of setting my idle a bit higher but thats just masking the problem....
All suggestions welcomed...
Old Nov 27, 2008 | 03:36 PM
Derex'8's Avatar
ReDuX
well I should also add I accidently broke off one of the nipples on the purge solenoid(trying to get it off that damn harness) Could this be the problem? even though that nipple hole is so small(and I mean minute)
