Where is the ground strap bolted?
Old Oct 20, 2008 | 11:43 AM
d05's Avatar
d05
I'm trying to measure the wire lengths in my engine for a "big three upgrade". The battery positive to alternator and battery negative to engine block are no-brainers, but I'm having trouble locating the stock engine block to chassis cable. I thought it would continue from the same point where the battery negative to engine block cable terminated, but I don't see it there. Any instruction/pics would be appreciated.
EDIT: Okay, on my latest search, I think I may have found the culprit. I'll attach some pictures, and if anyone would be willing to simply confirm whether I've identified it, that would be super.
Attached Thumbnails Where is the ground strap bolted?-gstrap01.jpg   Where is the ground strap bolted?-gstrap02.jpg
Old Oct 20, 2008 | 04:09 PM
Juice's Avatar
I made some poos
Thats where I put my Ground, from the lower intake manifold to the chassis. Lurch519 did a good DIY for a grounding kit. You should look in there, that is what I based mine off of.
Old Oct 20, 2008 | 04:22 PM
Socket7's Avatar
ಠ_ಠ
yeah, thats it. My grounding kit hits all kinds of different grounding points. Not sure how much benefit I see from all that 4 gauge running around the engine bay, but it sure looks shiny.
Old Oct 20, 2008 | 04:32 PM
StealthTL's Avatar
Metatron
You should use some black shrink-wrap on the ones that run to the negative terminal - Some dealermonkey or AAARoadGuy will boost you in reverse and blow up your ECU, and then blame the whole thing on you.....
Hear me now, and believe me later.
I have TWO of those cables to each ground point, but BLACK at the battery!
S
Old Oct 21, 2008 | 08:40 AM
Socket7's Avatar
ಠ_ಠ
You make a good point stealth, and since the terminal is covered by the battery lid, I think I can stoop to ruining the color scheme to prevent someone from being an idiot.
I happen to like the idea of all red wires. Keeps people on their toes.
Old Oct 21, 2008 | 09:18 AM
firebirdude's Avatar
User and Abuser
Black wire loom with black ring terminals.. And jesus. Clean it up a little.
Old Oct 21, 2008 | 02:03 PM
Socket7's Avatar
ಠ_ಠ
yeah. Those water spots on the sway bar look terrible
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
He||hammer
Sep 29, 2015 09:40 PM
Learners_Permit
Sep 27, 2015 07:38 PM
