Question for FI guys regarding the stock transmission
Old Oct 15, 2008 | 05:22 PM
MHopkins's Avatar
A friend of mine has an 08 RX-8 and he's been considering going either going turbocharged or supercharged because being in California you get a grace period before you are actively smog tested, so we figure now is the time to get a number of years of fun in unimpeded.
But anyway my question was regarding the stock MT in the 8. For those that are running either a turbo or supercharger kit on their 8, are you using the stock transmission or some other tranny swap (FD, FC TII, T56?)?
If you are on the stock tranny, how long have you had the kit and how many miles approx have you put on with it?
From my searching on this board I basically found that the stock tranny isn't beefy enough for race duty but otherwise should be ok for a mostly daily-driven, occasional spirited driving 8 even if boosted?
Old Oct 15, 2008 | 05:29 PM
Renesis07's Avatar
Vtak just kicked in yo!!
PM mysql.
Old Oct 15, 2008 | 05:30 PM
the stock transmission is being used by quite a few FI guys and it seems to be holding up well.
With that said, if you're pushing over 330+ hp, that transmission wont' last too long.
FD transmission seems to be a good route if you're breaking transmissions
Old Oct 15, 2008 | 05:43 PM
MHopkins's Avatar
330rwhp yes?
I don't think my friend plans on shooting that high. We're thinking probably 250-300rwhp tops. He doesn't really want to pay as much as it'd cost to get to around 350 along with the transmission concerns, and it'd be more power than he'd know what to do with.
Thanks for the input, hope more people chime in on their experiences thus far.
Old Oct 15, 2008 | 05:44 PM
MHopkins's Avatar
Originally Posted by Renesis07
PM mysql.
Really? Or is this like the joke on the rx7club "PM djdino for the smog hookup" =P
I did see a lot of posts my mysql though when I was searching last night about transmissions and turbo kits.
Old Oct 15, 2008 | 05:47 PM
mysql put a lot of miles on his turbo'd 8, he might have some insight.
Also, Mazdamaniac is currently well above the 300 hp mark and is still on the stock transmission. (though he does have an FD transmission in the garage for when the inevitable happens)
Old Oct 16, 2008 | 01:18 AM
california style's Avatar
Londons Yellow Peril
stock should be fine upto 300 HP, unless your friend plans on doing a lot of drag racing or other clutch / drive train abuse activities.
Old Oct 17, 2008 | 01:50 AM
chickenwafer's Avatar
Nope
The syncros is what usually goes in the transmission. I just take it easy shifting and make sure the clutch pedal is pressed down all the way. If you're going for 300-rwhp or under, you'll be fine.
To swap in any other transmission you're looking at a custom PPF, which won't be cheap
Old Oct 17, 2008 | 01:17 PM
olddragger's Avatar
yep pettit kit here--no problems with trans other than the usual stuff--i do track(not drag) --but i respect the syncos and mantainence.
OD
Old Oct 17, 2008 | 01:22 PM
rotary.enthusiast's Avatar
The Local Idiot
I am willing to bet at least 40% of the "weak" transmissions were a result of clutch pedal failure. MM has hammered his tranny a bit over the years and the only reason I am on my second trans is because I ham-fisted it last year and chewed it up. The boneyard tranny I swapped in has been holding up nicely and I have really laid into it a few times. The key is to remember that it isn't a "dog-box". Besides, the 5-speeds aren't all THAT much stronger than what we have now. The 20B guys snapped their input shafts on their 6-speeds at 400 h.p.
I think TeamRX8 might argue with you here
Old Oct 17, 2008 | 01:41 PM
He'll likely be the first to say he's not to nice to his transmissions
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Dokuji
Nov 1, 2016 02:51 PM
