How does this RP Supercat look?
Old Oct 1, 2008 | 08:06 PM
poweredbyplaav's Avatar
So i am about to purchase a used supercat, and wanted be sure that its okay. Is it normal to look like that in the first picture? Also, the seller is not including the bolts and gaskets. Are they something i can get from a local Pep Boys or do i have to get it from Rotary Performance?
Any advice would be appreciated!
Old Oct 1, 2008 | 08:16 PM
chancejat's Avatar
Drive it like u stole it!
ask greddygreddy for the gaskets....
Old Oct 1, 2008 | 08:20 PM
who is greddygreddy? do you mean greddy the company or is greddygreddy a user name?
Old Oct 1, 2008 | 08:37 PM
GODFATHER's Avatar
Iraqi Freedom Veteran x2
the bolts and gaskets can come from rp or someone on the forums, or any mazda dealership.... the super cat that you show in the pic is the 1st gen one. it looks like as far as a digital picture can show it still looks good. this cat flows good but a 2nd gen rp supercat will flow a little better.... if you have any questions just call us 972 530 3335 or email us at rpsales@rx7.com
Old Oct 1, 2008 | 08:51 PM
so they gasket and bolts can be found in other places than directly from you guys right? when i got my greddy catback, i was able to get the bolts and the exact gasket from pep boys.
Old Oct 1, 2008 | 09:04 PM
GODFATHER's Avatar
you know i'm not sure about pep boys having them, but they are only a phone call away .... and yea you can get them other than from us if you really want to be cheap bang out the studs on your stock cat and use the old gaskets off your stock cat... but i wouldn't recommend it.... it might work just fine for you but its just better to put new gaskets and bolts on there
Old Oct 1, 2008 | 09:08 PM
Well its not so much the cost factor as much as the time i have to wait to get it shipped over. But i guess ill go with the new ones from you guys. One other question, in case the cat were to go bad, would I still be eligible of sending it back to RP even though i would be the second owner?
Old Oct 1, 2008 | 09:17 PM
GODFATHER's Avatar
our gasket kit is like 30.00 and we would have to ask "the man" Ari about that one... if you want you can call or email tomorrow and talk to him.
Old Oct 1, 2008 | 09:20 PM
Thanks for the help!
Old Oct 1, 2008 | 09:22 PM
GODFATHER's Avatar
anytime buddy!
Old Oct 2, 2008 | 12:11 AM
wow,
somehow i mentioned a photo of the cat.. and the people that make the pipes show up..
to the op.. that photo shows a very healthy cat..
to rp..
what is the newest version and do you have a photo of the insides of it?
Old Oct 7, 2008 | 02:56 AM
So i'm supposed to be receiving the supercat in the mail in about 12 hours, and i was wondering: where the flange of the supercat (as shown in pic 1) connects to the downpipe, would i be using the stock gasket (whatever that there right now)?
i think when you buy the gasket/bolt kit from rp, they only give you the "donut" gasket that connects the other end of the cat to the exhaust. so what happens to the other end of the cat?
Old Oct 7, 2008 | 02:57 AM
i would have bought the bolts/gasket from rp directly, but i really want to install the supercat right away, so i am going to come up with the necessary gasket or gaskets and bolts on my own.
Old Oct 7, 2008 | 06:50 AM
r0tor's Avatar
Originally Posted by swoope
wow,
+1 as I still have an orignial design
Old Oct 7, 2008 | 10:27 AM
nuke0907's Avatar
Never Blend In
you can re-use the old gaskets.
for the front 3 bolt flange just get some stainless steel bolts from an autoparts store. should be an M10x40mm with standard threads. you will also need an M10 nut and a lock washer.
for the rear 2 bolt flange(the one with the springs), you will have to get the studs from mazda if yours are siezed like mine were. otherwise you should still be able to use the old ones.
Old Oct 7, 2008 | 01:08 PM
thanks!
Old Oct 7, 2008 | 04:41 PM
8 Maniac's Avatar
Senior Member
I'll take some pics of mine in a minute... gotta go get it out of the box really quick... brb!
Old Oct 7, 2008 | 05:02 PM
Fanman's Avatar
Might want to go to Star & get a set of stock gaskets. Last thing you need is leaks in your exhaust. Reusing gakets is usually not recommended.
Old Oct 7, 2008 | 05:03 PM
8 Maniac's Avatar
Senior Member
and back...
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
Jvswan
28
Jul 23, 2015 09:02 AM
N10S
44
Jul 29, 2008 07:40 AM
c41250n
22
Oct 12, 2006 11:49 PM
Chris_Bangle
41
Apr 3, 2006 09:54 PM
