Amp Overheating
Old Sep 29, 2008 | 05:47 PM
Chadwisk's Avatar
Moar Low!
Amp Overheating
Yea so on these hot summer days that i wont have to worry about in a couple months but for the time being my amp overheats sometimes. It is placed in the trunk in the rectangular cut out. Just driving around and my sub turns off. So I dont know if there's any way to prevent this from overheating. Thank god the amp has a automatic shut off if it gets too hot or else I'd be EFFFFED. Anyways, feel free to share your ideas. ENLIGHTEN ME!
~Chad
Old Sep 29, 2008 | 05:49 PM
invasion08's Avatar
Add a little computer type fan to the amp. Or get a different amp i have JL audio amp and have no problems with overheating
Old Sep 29, 2008 | 05:53 PM
Chadwisk's Avatar
Moar Low!
ya i was thinking about getting a little computer fan or something but maybe theres an easier solution because i have no idea how i would even hook the computer fan up to the car.
Old Sep 29, 2008 | 06:13 PM
Socket7's Avatar
ಠ_ಠ
they run off 12v. put a relay on the remote line and use it to trigger the fans when the remote line goes hot. You might be able to run straight off the remote line, but it's really not designed to handle actual current draw and you may damage something, so use the remote line to trip a 12v relay and flip the fans on, or don't come crying to me when your remote line stops working.
what are the impedances of your speakers? if you're running 2 ohm speakers and the amp is rated for 4 minimum, that would cause overheating. I'm going to assume you've hooked everything up right though and you just need more cooling. PErsonally, I'd make some sort of enclosure around the amp, then have 2 fans, one pushing air out, and one pulling air in on the other side. This way you get a steady flow of air over the amp.
Old Sep 29, 2008 | 09:19 PM
invasion08's Avatar
What type of amp do you have. I have my amp between the back of the back seat and spare tire kit and no problems.
Old Oct 1, 2008 | 06:27 AM
m1pui's Avatar
Try moving the amp out of the well in the boot. That gets hot from the exhaust anyways so it's not doing it any favours by installing it in there.
As invasion said, seatback, or one of the side walls of the boot/trunk, is the way to go
Old Oct 1, 2008 | 10:00 AM
jeffe19007's Avatar
I agree with getting off the floor of the trunk. The stock exhaust gets it pretty hot.
I open the pass through in the summer for my carputer. Maybe that will buy you some time while you figure something out. A little cool cockpit air helps.
Old Oct 2, 2008 | 08:02 PM
firebirdude's Avatar
User and Abuser
I didn't read all replies, so pardon in advance.
Mine kicks off on long drives too. I have to be cranking it for nearly an hour before it happens, but it does. You can back the gain down a touch on your amp and/or add a fan setup of some kind. I have noticed having the passthrough in/out and AC on/off makes no difference in my case. If it does, it's 5 extra minutes of play time. Big deal.
Old Oct 18, 2008 | 02:07 PM
Chadwisk's Avatar
Moar Low!
Rocksford Fosgate 300w Amp and its bolted down to the floor where the indent is. I cant put it behind the seat or center console because that is where my sub box is. need a fix. maybe instead of a fan ill just raise it up. I dont know its winter almost now so ill be good to raise some money and fix it before next summer.
Thanks guys
~Chad
Old Oct 18, 2008 | 02:10 PM
odd that you guys are overheating the amp.
I have a Kicker 1200 watt mono channel that sits in the 'trunk organizer' with the lid on and I've never had my subs cut out.
Those who know me know that I dont go easy on my stereo, I've got an aftermarket exhaust, AND it's over 100+ degrees here in the summer.
Old Oct 18, 2008 | 02:15 PM
HeavyMetal699's Avatar
If I'm not mistaken your trunk is dynamatted. Do you think that could be the big difference?
With the muffler(stock exhaust) directly underneath it, I know it gets quite warm sometimes.
Old Oct 18, 2008 | 02:18 PM
yeah, I dynamatted the HELL out of the trunk.
Old Oct 18, 2008 | 02:32 PM
Renesis07's Avatar
Vtak just kicked in yo!!
Holy cow! After AN HOUR it overheats?!
I drove home from Cali to Chicago, over 28 hour drive and my system didnt go below volume 20 the whole time and it NEVER had a problem (Lowered 8 w/ droning midpipe + typhoon intake going 80mph=noisy). I have a JL Amp with 2 10'' W1's and its never shut off from overheating; had the system for almost 2 years now.
Old Oct 18, 2008 | 02:34 PM
laythor's Avatar
I zoom therefore I am.
In Jedi's trunk, no one can hear you scream.
Old Oct 18, 2008 | 03:39 PM
rled's Avatar
5Picker
Is your power wire building heat? You may need to oversize your power wire to the amp. Is the wire getting overly warm? Heat causes resistance to rise in the wire. As the resistance goes up so does the amperage to overcome the resistance to maintain the voltage.
Old Oct 18, 2008 | 06:30 PM
User and Abuser
Yeah. No big deal honestly. I rarely drive that far. Maybe 5 times a year. And if I was to just keep the volume to a "normal" level, I wouldn't have problems..... but that's no fun.
Old Oct 18, 2008 | 06:32 PM
Originally Posted by laythor
In Jedi's trunk, no one can here you scream.
I lol'd !
Old Oct 18, 2008 | 07:00 PM
Rote8's Avatar
~Chad
Check the speaker(s) for proper Ohms for the circuit.
A 2 ohm speaker on an amp made for 4 or 8 ohms will over heat the amp.
Old Oct 18, 2008 | 07:20 PM
yushinrt's Avatar
do you amp come with fans ? if not you should try to put a little computer fan or something?
Old Oct 24, 2008 | 03:51 AM
feimotion338's Avatar
Angry coolrunescape.com you can buy cheap, fast runescape gold about money making
..........spam............S
tommy26Germany
Sep 29, 2015 10:33 AM
Learners_Permit
Sep 27, 2015 07:38 PM
juicemantwon
Sep 26, 2015 12:30 PM
just1jack
Sep 9, 2015 04:45 PM
